Refitted engine not firing on all cylinders!
Hmmm,
Just refitted the engine in my SC after a body resto. Tidied up the tinware and changed manfolds and some seals, but other than a change of oils & filters, nothing else done on the unit.
fired up after oil primed and fuel sent through, just not on all cylinders!
Could it be an air lock in the CIS fuelling system?
Cheers
Old 09-17-2014, 11:35 AM
ROW '78 911 Targa
timmy2's Avatar
Did you bleed the system?
Turn on the ignition and lift the lever in the air box to get fuel to flow to the injectors. If they are squealing they are primed.
Doesn't take more than a few seconds. Don't do it longer that 3-5 seconds as it will flood the cylinders.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-17-2014, 12:09 PM
French Import
zippy_gg's Avatar
Did you at some point remove the spark plug wires, on either the plug or dizzy side?
If so check that they were reconnected to the proper cylinder. That should take care of basic spark since other cylinders are firing
Also check that all fuel injector connectors are on correctly. Fuel
Did you make sure you removed any rags left behind when putting back on the intake manifold? Air
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 09-17-2014, 12:10 PM
Brew Master
cabmandone's Avatar
My guess is somehow you got your timing whacked or put a plug wire on the wrong cylinder.
Did you pull plugs or change plug wires?
Old 09-17-2014, 06:24 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by stuarts View Post
and changed manfolds...............
The ol' manfold change can wreak havoc.
Expound upon this.
Also, where are you based?
1981 911SC Targa
Old 09-17-2014, 08:02 PM
Banned
It looks like April followed my instructions!
Old 09-17-2014, 08:37 PM
All plugs are wired up correct, I marked up the dizzy so that's gone back in the same position.
So, whats this story with the manifolds?
Old 09-18-2014, 12:16 AM
So, doesn't appear to be a timing or loose plug issue.
Definitely feels like it's not getting fueled properly, will fire up instantly, sounds like a rough beetle at idle (though does idle). real hesitant throttle response, then when backing off the throttle (only took it to 3 thou, not really revved), revs drop right off then flutter.
Nothing has been adjusted before/during/since the engine refitted.
Old 09-22-2014, 03:58 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Maybe firing on one bank only...
Listen to the injectors (Stethoscope or long screw driver) to see if all six are clicking.
Who Will Live... Will See
Old 09-22-2014, 05:13 AM
