gtrp's Avatar
Weak spark causing unburnt fuel?
Car will start up perfect but idle slightly low around 500-750. After about a minute or even after 10 minutes, it'll drop rpms and run rough until it coughs up unburnt fuel and stalls.
Changed the rotor, cap, wires, fuses, and the sensor under the seat after the issue developed and I saw sparks across my wires. Car was running perfect until I drove it in the rain... Any ideas?
81' Widebody SC
Widebody 911SC
Old 12-30-2014, 06:32 PM
Discseven's Avatar
GT... sparks across what wires?
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 12-30-2014, 06:59 PM
gtrp's Avatar
Across my spark plug wires, was a nice light show.
Old 12-30-2014, 07:02 PM
Unmetered air entering the intake. Did you experience a backfire?
Or you installed your plug wires in the wrong order, double check the firing order.
Arcing across the wires likely means you have bad wires, may be its time to replace them.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
gtrp's Avatar
I am going to check the injectors next to see if I have uneven spray. Might as well put in new spark plugs too, wish we could buy them pre-gapped.
I fixed my vacuum leaks recently along with new fuel lines, fuel filter, and fuel accumulator.
Old 12-30-2014, 07:06 PM
gtrp's Avatar
I'll double check the order.
I had a bad vacuum leak before which caused a poor idle but never unburnt fuel to come out of my exhaust.. Interesting. No backfires here and I have a Popoff valve that is sealed good as well.
Old 12-30-2014, 07:08 PM
gtrp's Avatar
Just did that tonight, still same issue.
Old 12-30-2014, 07:10 PM
Check your spark plugs, you may have fouled plugs, and you could have water in your plug wells which may contribute to the arcing of your wires.
Gapping plugs is pretty straightforward, they usually come gapped correctly but it is always best to check them.
There should be a woven 1/2" ground strap in the upper drivers side of the engine compartment make sure those connections are clean and dry as many electrical and ignition issues can be caused by a bad ground.
Old 12-30-2014, 07:20 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Make certain the connectors are fully seated on the cap, the new wires will be tight and may create an air pocket allowing it not to seat all the way. Use a pick tool and some di-electric grease and let any trapped air out. Also you should feel and maybe hear a click when properly seated.
To answer your question, yes weak spark will burn less fuel.
If you want to insure you get the most optimal spark, pull spark plug wire and place a new plug for testing the current, ground the plug and have someone crank the car. You should see a blueish spark, if more yellow or worse orange then the wire or cap/rotor may be defective. Pull the fuel pump fuse to disable the fuel while cranking.
Jim
'85 Carrera Targa
PCA/POC
Old 12-30-2014, 07:22 PM
T77911S's Avatar
is it driveable?
stuck plunger in the fuel head
bad WUR
bad mixture
bad CSV-i dont really hear much about them being bad though
start it up, reach inside the air box and pull the sensor plate down. if it runs better it is too rich.
push it up, if it runs better it is too lean.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-31-2014, 03:45 AM
VFR750's Avatar
If you had a good idle before you fixed vacuum leaks, your idle screw might have been turned in.
The start idle speed should be 1200 or so, dropping to 950 after a bit.
You might need to open up the idle speed screw to allow the metered flow to increase and get the idle rpm back to where it needs to be.
Btw, new plug wires should fix the arcing. And eliminate the effect of dampness that you experienced.
Old 12-31-2014, 05:49 AM
81' Widebody SC
Great hint. You might check for moisture inside your distributor. Seems like a very common problem after exposure to rain.
Cheers,
Joe
Old 12-31-2014, 06:21 AM
gtrp's Avatar
Thanks, I'm going to try everyone's suggestion one at a time and report back what I find.
Hopefully it's just an ignition issue and not a fuel issue.
81' Widebody SC
Widebody 911SC
Old 12-31-2014, 05:50 PM
gtrp's Avatar
Originally Posted by T77911S View Post
is it driveable?
bad WUR
bad mixture
Tried the sensor trick while the car started dieing and it wasn't able to keep the car alive either way. I think my mixture setting is good and don't want to mess with it too much.
81' Widebody SC
Widebody 911SC
Old 12-31-2014, 05:52 PM
Hard to imagine how improper mixture, vacuum leaks, WUR failure, injector spray patterns and plug gaps could suddenly appear as the result of rain. However, moisture infiltrating ignition components could easily create havoc causing symptoms as described.
Cheers,
Joe
Old 01-02-2015, 05:44 AM
