Discseven's Avatar
Originally Posted by techman1 View Post
great news, good luck with your alignment work!
Thanks TECH!
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 11-07-2014, 12:26 PM
Discseven's Avatar
Originally Posted by CCM911 View Post
... I tightened down all my manifold bolts...
Chris... you have stock engine in car? If so... tightening all is impressive. Did you get to them with or without removing parts?
Karl ~~~
Old 11-07-2014, 12:34 PM
Karl, I did a similar clean of the ICV valve that you did. It would work for a while but it was like it was worn out and the problem would return. After a few cleanings I just bit the bullet and bought a new one. That fixed it for for last many years.
With luck your valve will stay clean and you will not need a new one. I was not so lucky.
Old 11-07-2014, 12:47 PM
LOVEHZ's Avatar
What adjustment is the arrow pointing to? Thats what smoothed our my idle. Lots of hunting when warm.
Old 11-07-2014, 12:50 PM
Discseven's Avatar
Will keep this in mind Glenn... TY for note.
Karl ~~~
Old 11-07-2014, 01:11 PM
Discseven's Avatar
Is indeed idle adjustment for Motronic HZ. Dug around and came up with some images posted by Ed Sully and Rusnak --- thanks guys... am recycling them.
TY Ed
TY Rusnak
Karl ~~~
Old 11-07-2014, 01:33 PM
Disc, not too impressive, as I run a cone air filter, LOL. I used a long extension with a universal joint and it worked great.
I hope you are having fun. Once you get this fixed, you will be so happy. Unfortunately, it is usually more than one thing, so just be persistent.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 11-10-2014, 07:20 AM
Discseven's Avatar
Sure.... and no hot air blower. Waltz in the park for you! Am thinking to get all that out of the way but mind plays with me---am hooked on keeping it stock for some odd reason.
Cleaning ICV and tightening its 3 internal contacts seemed the cure in my case.
TY for input Chris.
Karl ~~~
Old 11-10-2014, 07:33 AM
LOVEHZ's Avatar
TY Ed
TY Rusnak
I find when the idle speed is not adjusted properly, my 911 will hunt when warm. Could be something that simple.
Old 11-11-2014, 04:33 PM
