Diss Member
Most of the big things I'd check have been mentioned:
- Intake bolts to 18 ft/lbs (the gaskets under them can be cracked so not a sure fix.) - Cracked hoses. After this many years there is almost certainly toasty hoses. - ICV is possible. A number of articles on checking that. - One I haven't seen is the cylinder head temp sensor. Most important is TEST not REPLACE. (Always drives me crazy to watch someone dueling with their car blindfolded with shotguns.) A good test for the intake is to use an infrared thermometer gun to read the exhaust port temps after startup. A vacuum leak in the port can cause a port to read cold. Full throttle it will run fine. ------- Helpful hints for anyone that needs to replace their intake gaskets... - There are 2 gaskets for each port. One below and one above the plastic spacer. - The plastic spacer will need to be replaced if you open it up. At this age they are crumbling. ------------ Oh yeah... And as mentioned before: Ignore the advice from people referring to cars 1983 or before, or referring to "SC" or CIS". Their cars are completely different and are not electronically managed.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. Last edited by Quicksilver; 11-04-2014 at 12:24 PM.. |
Ahhh... Those! TY
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Yea, it was a weird mystery how two of the bolts that hold the intake down could be loose. The others all came off with that nice snap. Two were just finger tight.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Looks like you caught this before I posted. No worries.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 11-04-2014 at 02:25 PM.. Reason: Caught it |
Nice deduction at the end Tech. Suggests where to start. TY for input.
![]() Evidence is building for sticky ICV.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 11-04-2014 at 02:54 PM.. |
Updated Checklist:
To keep track of info, am listing suggested causes, tests, recommended fixes, and relative links. Will move this forward as it's updated. Please advise correction(s) if you see anything wrong. O2 sensor - Test (how?) Air blending valve - remove and clean (if hunting exists when engine is cold... 02 sensor can be ruled out) - searched for Air Blending Valve and did not find fuel related info. Are we talking ICV/ISV here? Idle mixture too rich - lean out idle mixture - Pelican Technical Article: The Motronic Engine Management System - 911 (1984-89) - ICV - remove and test / clean - Idle Valve Intake manifold bolt tightness - check tightness (18 ftlbs --- not sure what years this applies to). Good test for the intake is to use an infrared thermometer gun to read the exhaust port temps after startup. A vacuum leak in the port can cause a port to read cold. Full throttle it will run fine. Intake manifold gaskets - Helpful hints for anyone that needs to replace their intake gaskets... - There are 2 gaskets for each port. One below and one above the plastic spacer. - The plastic spacer will need to be replaced if you open it up. At this age they are crumbling. TY for input guys.
Tomorrow am into ICV/ISV and will check intake bolts.
Worked with DME before,ICV failure is rare and yes they can be cleaned and will work again,check for a buzzing noise with the key on if not don't dive in and buy a new one cause they are $$$$ new,check the plug on to it first,they do get old and don't connect properly,the result of this is a rolling idle from say 900 to 1200rpm or stalling after coming off throttle.
If you have air leaks the ICV gets out of running range and your idle will increase past what it will compensate for,as mentioned check the inlet manifolds for leaks. O2 sensor normally won't effect idle but will cause a rich (default) condition after normal driving and increased fuel consumption,make sure your replacement one is exactly speced for your model and not a cheap universal one,ask me how I know ![]() Think there should be a new tech book called "101 places for air leaks on EFI systems" because IMO this is the primary cause of issues.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Diss Member
The bad intake gaskets were kind of a blessing in disguise. I had to take off the intake and I discovered a couple cracked vacuum lines, some lines hardened to the point where they cracked on reassembly, and the biggie was that the crimped connections in the fuel lines would spin like they were bearings. Glad I caught that before the Car-B-Que.An intake teardown to replace rubber parts is a good preventative measure on cars of this age.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
It does have a fast idle when cold. Quote:
Sal is the expert on all of this.
Rick 88 Cab |
Car-B-Que. Saw one some years ago on highway. 911 engine fire off to side of road and guy obviously had no extinguisher---just standing back watching it burn. Sinking feeling. With you on rubber replacement Wayne.
Good note on gasket access Rick. Am questioning whether I want to go that far at this time. Have other projects lined up so am hoping this idle hunt will be a quick resolve.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 11-05-2014 at 04:03 PM.. |
Today...
Pulled ICV and removed case to check guts. Rotation doesn't seem sticky but not sure how delicate the movement of valve is. NOTE: Valve does not go round and round. It opens in one direction... and reverses to close. Here's looking into valve... open then closed. A bit of gunk can be seen on closed valve. ![]() Brake cleaned valve area. O-ring is in good, pliable condition. So are hoses. Now am going to clean crud off electricals... ![]() Inside housing are 3 contacts. Will bend them in slightly towards center. Beyond contacts there's floating plastic shield. That can fall out if not careful. ![]() Obvious weak link in this area (in my engine) is top hose connection to intake plenum. That connection came apart with very little effort. Am going to replace the 2 crimped hose clamps there with screw clamps asap. ![]() Went for 20 mile city drive afterwards. Did a couple of "Pablo variations" ...no more hunting. RPM is now near 800. ![]() Had planned to check intake manifold bolts today but ran out of time. Is on tomorrow's menu.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 11-05-2014 at 07:29 PM.. Reason: Learning to spell |
Fix = Clean ICV valve passageway with brake cleaner, slightly bend in 3 internal contacts, clean o-ring.
Also replaced 2 old crimp clamps that make connection at air intake plenum seen below (because this connection pulled out far to easy.) This was done after hunting was corrected so not necessary at moment but no need to leave it to loosen further. ![]() ![]() Installed screw clamps but they don't fit visually compared to (solid) stock clamps. Will sort this out later. ![]() Considered checking intake manifold bolt tightness but to access all of them... it's no small undertaking. So, sampled #4's intake bolts. Definitely under 18 ft lbs. Left bolts where they were. Will deal with this come next year's case split. TY for input guys.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 11-07-2014 at 04:45 AM.. |
Great news, good luck with your alignment work!
I would also add that you really don't want to mess with the mixture. All that will do is mask the real problem. As stated before, ICV, and then vacuum leaks. I tightened down all my manifold bolts, chased down all my leaks and then bought a used(know good) ICV, and replaced my high pressure fuel lines. Now my idle is fine.
I think too many people want to dive in and start monkeying with the mixture settings. Not the best way to go in my humble opinion.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
