Idle hunting... why? How to fix?
Got '85 3.2 that's starting to hunt at idle. Pulses between 1,100 rpm and 1,200 a few times... then settles down to 1,000. Interested in what causes this. More interested in how to fix whatever's wrong.
EDITS: Only does when engine warmed. O2 sensor replaced about 18 months ago.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 11-04-2014 at 05:23 AM.. |
Fb = M/S
On my 81 SC it was a combination of a bad O2 sensor, and fuel mixture. Also, the hunting at idle was continuous after the engine warmed up.
1981 911SC, Guards Red/Black Leather 2014 Audi A6 Prestige, Phantom Black Pearl/Black Leather, Black Optics 2017 Tesla Model X Gone but not forgotten: 1969 Datsun 2000, 1973 914 1.7, 1976 912E |
TY Curl. Replaced 02 sense roughly 18 months ago... no guarantee but am thinking that's OK. Can you tell me how you adjusted mixture?
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Always Be Fixing Cars
almost certainly the idle air blending valve. Pull it, clean it, clean the contacts on it. Mine was hunting in the same way and the above cured it - not instantly - but over the course of a few months of driving it got better and better to the point where I rarely see it any more.
I should back up and say I was so sure of my diagnosis in my case because It was a on a freshly rebuilt motor with all new o2, sensors etc etc. However if the symptoms exist when the motor is cold you can rule out the 02 as it is being ignored by the DME.
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
Easily Confused
A rich idle mixture will do this. It gets rich, revs up then the DME pulls the idle back down.
After the car warms up and uses the O2 sensor circuit it goes away. This symptom typically shows up when the temps drop down in the fall. There is quite a bit of documentation on this topic on the board.
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
Take the ICV off and see if the valve moves when you shake it in your hand. If not, spray some carb cleaner in there to clean it up so it moves freely again. Reinstall and fire up the car. Mine was doing something similar so I did this and the hunting is gone.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
LOL... really XNO, just shake it?! Is there any "carefully" with that or just load in with martini and shake?
To keep track of input, am listing suggested causes, recommended fixes, and relative links. Will move this forward as it's updated.
O2 sensor - replace (mine's not that old so will leave it be for time being.) Air blending valve - remove and clean (if hunting exists when engine is cold... 02 sensor can be ruled out) - I searched for "Air Blending Valve" and did not find fuel related info Idle mixture too rich - lean out idle mixture - Pelican Technical Article: The Motronic Engine Management System - 911 (1984-89) - ICV / Idle Control Valve - remove and test / clean - Idle Valve
When I had a the idle hunting problem it was a vacuum leak. One of the rubber hoses from the oil tank was cracked.
It is astonishing how dead steady the idle is on my car after the total rebuild. Most of that I attribute to the good seal of all the intake and fresh rubber on every connection. two of the intake bolts were just finger tight. How they got loose is a total mystery. I don't think that intake had ever been touched before. The ICV is a good place to start. I tried to clean mine in the past and had no luck on a long term fix. It is easy to replace so I put a new one on and that fixed it. I have had my 911 for 19 years and driven it myself for 90,000 miles so a lot of problems have popped up more than once and be fixed. They kinda run together in my brain.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! Last edited by GH85Carrera; 11-04-2014 at 01:08 PM.. |
The ones the hold the intake runners down. There are two on each cylinder sealed with a individual gasket.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
As far as I can ascertain, the ICV has a coil of some kind on the left end that the connector goes into. The valve is coaxial to the coil. So when the system opens and closes the valve by applying voltage to the coil, the valve is actually rotating. If you remove the ICV and look at the air intake part you'll see what I mean.To be more specific, if you rotate the ICV in your hand like it's a screwdriver and you're quickly turning it, you should see the valve rotate in there. Mine seemed pretty sticky, and there was a good amount of black "soot" in there. So I sprayed some carb cleaner to clean it out. I could then rotate it, and the valve was way more free and "floppy" in there. So in my mind, the DME was trying to move the ICV during idle, but the ICV was slow to react due to the valve being sticky, which was responsible for my hunting. The nice thing about checking the ICV is it's free
Fb = M/S
My mechanic adjusted the mixture, so I am not really sure what they did. I did have to recently take to a mechanic to adjust the mixture again, as it was stalling and bucking between 2000-3000 RPM. I watched him - he took off the airbox cover, and used a ratchet at something near the fuel distributor. He also adjusted the idle screw and it ran great. Took him 5 minutes and it passed smog too!
Is there a way to do this without a CO meter?
Use the o2 sensor perhaps? paging scarceller?
Rick 88 Cab |
I would bet the Idle Speed Valve, or ISV. Others referred to it as the blending valve above. On a cold engine, the DME tells it to open, adds more air to the engine. as the car warms up, the idle starts to raise, the DME tells the ISV to close some. If it doesn't, the idle gets higher, car gets warmer, until it hits the DME limit of about 1200 rpm. DME cuts the signal, maybe to the injectors, I am not sure. The idle drops, signal is restored, idle increases cause the ISV is still stuck open, repeat.
Could be other things, like a vacuum / intake leak. What is happening is the idle gets too high because of the extra air, and the ISV is closed all the way, so it can't help. Pulsing starts. Since you said it will eventually stop pulsing, and a vacuum leak would stay leaking, I am pretty sure it is a sticky ISV. |
Sorry plz ignore 81' 911sc widebody
Widebody 911SC Last edited by gtrp; 11-04-2014 at 12:32 PM.. |
Go-Kart Mozart
85 3.2 with the factory chip should idle around 800 rpm. If you are idling at 1k and haven't made any adjustments I would put my money on a vacuum leak. Could be as simple as a cracked hose or loose intake runner. Hopefully you don't have to replace intake runner gaskets. Lots of info if you search 'idle bounce'.
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
