Oh Haha's Avatar
I found a good thread Home ride height and corner balance success story the tripod method.
Pacific Blue
Wayne
Old 11-07-2014, 06:29 AM
Discseven's Avatar
Yesterday... did front toe adjustment day. (Am not going to adjust caster---it's fine the way it is. Camber I have discovered is fully adjusted meaning top of struts are fully out from center of car. So where it is now is likely where it will stay. Have heard about places that will adjust the spindle but I want to run these tires and see what results are had from toe only adjustment set per Scruggs specs.)
Here's progression of measurements... starting with where I found front toe... after lowering, and where I brought it to (just inside 1/8" toe IN.)
Before dealing with rear camber then toe, I have spring plate problem to deal with---want to swing the spring plate down on passenger's side but can't get it to move. Also have creaking noise from rear when suspension travels. Help with these challenges would be appreciated.
NOYOUrelax... where are you at with your project?
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 11-07-2014, 07:05 AM
Originally Posted by Discseven View Post
$75 not including shipping. Not bad. TY for link Will. Am curious... have you done both a bat and this gizmo roll? Bottom line... can you compare them for us?
Unfortunately, no, I have not used the bat method. But after watching videos of people using bats, if the car was a race car or if I was getting ready to paint it, I'd have no problem using a bat.
Your original question was how to roll your fenders without cracking the paint. In my opinion, your best bet is to use a real fender roller. When you use one, they are really slick. The amount of control you have not only in how much you are rolling the fender lip over but how far you are rolling it is incredible.
Like I said in my earlier post, one of the keys to not cracking the paint is rolling the fender in small increments. Not just along the arch of the fender but also in not just totally rolling the lip in one pass. You need to make several passes rolling the fender just a little each pass. The fender roller tensions so easily that keeping the pressure of each pass uniform is a piece of cake. I probably used 6 or 7 passes to slowly roll my fender. Each pass I rolled the lip a little tighter to the fender.
Old 11-07-2014, 07:09 AM
Discseven's Avatar
Will... TY for notes. Q: did you compress the hanging lip entirely up against the inside of the fender so the roll is now flat? Any concern with rusting?
Karl ~~~
Old 11-07-2014, 07:25 AM
Discseven's Avatar
Craig did good on that write up... TY WAYNE. Increasingly apparent how much more knowledge I need to gain. Measuring off fenders does seem dubious. Will get into more accurate measures after preliminary adjustments.
Karl ~~~
Old 11-07-2014, 07:32 AM
Yeah, I rolled to the fender.
Before starting, I scrubbed the inside of my fenders to make sure that no residual dirt or grime was going to get trapped in the fender. I then rolled it onto itself. Then I ran a bead of silicone between the old fender lip and fender.
Between that and the galvanized front fenders, I'm not too concern about rust.
Old 11-07-2014, 07:51 AM
Discseven's Avatar
Excellent... TY For info Will. Post some pics if you're inclined.
Karl ~~~
Old 11-07-2014, 12:39 PM
Discseven's Avatar
Am returning to see what I can do about moving my stuck spring plate.
Karl ~~~
Old 11-10-2014, 09:39 AM
Bob930slant's Avatar
here is a pic of the wrench i made. 18 guage flat steel, cut to 36mm on one end and 24 mm on the other end. a little time with the grinder and in 15 minutes you will have your own custom rear suspension wrench for about $1.
81 930 Turbo RoW, Slantnose, 3.5 twin plug dual MSD 6AL ignition, MSD RPM Activated boost rdelay switch set at 4400, MSD Tach Adapter, BL Wur, 18x11 (315-30-18) and 18x8 (235-35-18), Fab speed exhaust, Innovate MTX, K&N Filter Mod., NGK BPR7EIX and DPR7EIX plugs, KEP Stage II PP with Street/Race Organic Disk., Weltmiester Swaybars, Adjustable AAR Mod, AAV Delete
Old 11-11-2014, 01:34 PM
Discseven's Avatar
$1.... Way to go Bob. Love it! TY for inspiration.
Is back side of those 24 mm's on spring plate 24 or 36?
Karl ~~~
Old 11-11-2014, 02:10 PM
Discseven's Avatar
Did Scruggs corner balance test today. Pulled slightly to right. Given right rear spring plate being lower than left, this should have put more weight on the left rear and right front... causing pull to left. Something's not right here.
Karl ~~~
Old 11-11-2014, 02:20 PM
bolt head on lock nut is 24 and the head of the ecentric is 36. here is a pic from the forum tech article that shows both sides
Old 11-11-2014, 03:18 PM
midnight911's Avatar
very nice.
way better than my ground down craftsman.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 11-11-2014, 10:48 PM
Discseven's Avatar
Excellent reference BOB. TY
Karl ~~~
Old 11-12-2014, 04:38 AM
Discseven's Avatar
BOB... what did you use to cut 18 gauge?
Karl ~~~
Old 11-12-2014, 04:40 AM
Member 911 Anonymous
DRACO A5OG's Avatar
You can also grind down a cheapo 24 MM wrench.
Going that low in front you should consider a bump steer kit.
'85 Carrera Targa
PCA/POC
Old 11-12-2014, 06:49 AM
Discseven's Avatar
Grind thick wrench down... damm fine idea Jim. TY
Suspension = all new to me so on big learning curve here. Bump steer. Heard of it but going to ding into some vids to get better acquainted. Ahhhh... I get it.
Investigating Bump Steer - YouTube
Longacre Bumpsteer Gauge Demo - YouTube (TY Sherwood)
Karl ~~~
Old 11-12-2014, 08:40 AM
Discseven's Avatar
Am still challenged by uneven spring plates. Been trying to move lower swung spring plate up and it's not happening. Do I have to disconnect everything from it in order for it to move?
Karl ~~~
Old 11-12-2014, 08:44 AM
Oh Haha's Avatar
tfhstuy reported as spam
Pacific Blue
Wayne
Old 11-12-2014, 09:42 AM
Discseven's Avatar
Spent afternoon attempting to raise right side spring plate slightly... finally said screw it. Am going to move on to corner balancing--perhaps spring plates are already in correct position! Preliminary Scruggs road test suggests more weight being on L front and R rear. Am going to use measure method to check CB.
Karl ~~~
Old 11-14-2014, 02:39 PM
