Which SSI hardware? Plz help :)
Guys,
I recently purchased a set of SSI's for my 79 3.0. Can someone please help me with which head to ssi gaskets I need? There appear to be a few different ones: 930-111-191-13-M30 and 930-111-191-13-M17 Also --- I assume these are the nuts that I should get to replace the old ones that hooked up the stock heat exchangers to the heads? 999-084-052-02-M260 Aaaaand… this is the muffler gasket? yes? 911-111-191-02-M17 Thanks! Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52 Last edited by sempaipaul; 12-07-2014 at 06:36 PM.. |
Anyone?
Your numbers look correct to me based on this UK site I used for reference when I fitted ssi's to my 3.4.
http://www.type911shop.co.uk/shop/category_71/Fittings-_-Heating.html?sessid=59c5FYVyMvAQNjL3SOUZWBUJifWDro XAayMAPCHytkurZAxyn6LJTL71hS6dTzyJ&shop_param=cid%3D%26
Shirish 1987 Carrera, Granite Green |
Excellent! Thanks!
Regards, Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52 |
I suggest using this link to confirm part numbers.
Porsche Original Parts Catalogue - Parts and Diagnostic Information - Porsche Service - Dr. Ing. h.c. F. Porsche AG Sherwood |
Y'know, in searching Pelican's offerings on gaskets for your application, I recall 25 years ago having the same question. Do you buy a gasket for the year engine that you have, or do you buy the pre-1974 gasket to match the SSIs? As I recall, I did the latter.
Brian |
Guys,
Finally getting around to this --- Do these nuts 999-084-052-02-M260 replace the old 8mm socket type of nut 999-085-001-02? Looks like I have the socket type on my SC right now. Let me know what your thoughts are! Regards, Paul
Not sure mechanical lock nuts are needed here. Nature has its way of locking these in place.
![]() At any rate, to stave off corrosion from future road muck, I suggest covering threads and fastener with anti-seize compound, before and after installing the nut. The socket-head nuts are factory and allow hex driver access through the HE, but not necessarily required if you can otherwise access them with the right wrench/tool. Sherwood BTW, the PParts description is a little confusing, "M8-13". M8 is the threaded shank OD, usually followed by the thread pitch; exhaust studs and other 911 fasteners are commonly used M8-1.25. The "13" probably refers to the wrench size for the hex nut. However, 12mm wrench-size M8 nuts are sometimes recommended to allow better tool access in that area as are nuts made of copper in either size for increased corrosion resistance. Last edited by 911pcars; 02-22-2015 at 12:37 PM.. |
So in other words I can replace the existing hex "nuts" with normal locking nuts with locking nylon…. correct? Thanks, Paul
For example: ![]() Sherwood |
Thread Tools | |
Rate This Thread | |
