P Car Addict
klober23's Avatar
Please verify this Perma Tune Box is Wired correctly
Can someone please verify if this Perma Tune Box Wiring looks correct?
RIP Grady Clay
Old 01-27-2015, 04:32 PM
ROW '78 911 Targa
timmy2's Avatar
Year of car would help, it does matter for where connections are made.
Where is the tach signal wire that should come out of the harness with the red wire?. It is normally white and connects to the purple/black wire on some years...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-27-2015, 06:09 PM
P Car Addict
klober23's Avatar
Dennis,
This is a 1973.5. It had a red wire running to double prong on the bottom of the Perma Tune, but there was also a SS braided ground there, that appeared to originally connect at this point. The red wire did not make sense.. the other white wire that comes off of the double prong on the bottom runs into the harness where the brown grounds connect to the side of the engine compartment.
RIP Grady Clay
Old 01-27-2015, 06:14 PM
looks pretty normal, for the info provided. what's the issue? no start? check point gap and see if they're old and crispy. permatunes have had failure issues for eons. do you have 12V to the center red wire with the key on?
206 637 4071
Old 01-27-2015, 06:20 PM
P Car Addict
klober23's Avatar
No issue yet, I am just completing something someone else started.. I adjusted the wiring to what you see in the picture as it was very different. I just wanted another set of eyes on it before I gave it a go.
Thanks, greatly appreciated.
RIP Grady Clay
Old 01-27-2015, 06:23 PM
al lkosmal's Avatar
permatune
1st pic is the end view of the plug from the Permatune website. The second pic is the wiring diagram for 73 911, showing the colors of the wires and location on the CDI plug.
regards,
al
PS: based on your pic/wire colors...It looks right.
RGruppe #669
http://www.x-faktory.com/
P Car Addict
klober23's Avatar
Perfect thank you!
RIP Grady Clay
Old 01-27-2015, 06:25 PM
ROW '78 911 Targa
timmy2's Avatar
Always helps to post the year, makes it easier to know what we are looking at.
Nice pictures Al.
Old 01-27-2015, 07:06 PM
