Certified User
billjam's Avatar
Testing reference sensor with oscilloscope ... how?
I am having some problems getting consistent, logical signals from the flywheel reference sensor (standard 3.6 sensor) at the MS3X ECU and I need help to figure out how to check the sensor with an oscilloscope as per the Porsche manual. Then the sensor can either be ruled in or out as the problem.
I should add that I have not been able to get good signals in the TunerStudio tooth logger. Sometimes I get nothing, sometimes a partial signal, sometimes a full 60-2 signal.
I have connected the oscilloscope to the sensor and get a trace running across the screen, but that's where I come to a dead stop. When I crank the engine, the trace goes all over the place and I can't figure out how to tune it so that it looks like the diagram in the manual below. If you hadn't already guessed, I now nothing about oscilloscopes ... I'm amazed that I even got this far!
There's lots of oscilloscope guides and how to's on the net, but I haven't been able to get past this stage, so I need some help from someone who has done this or knows how to setup this oscilloscope.
Can someone who is familiar with this type of scope give me some simple steps to follow? Pics below show current settings.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 03-07-2015, 08:34 PM
Chain fence eating turbo
Have you tried capture the signal inside the ECU? That's where I checked mine with a handheld o-scope that autoscales.
Might be easier.
Old 03-07-2015, 09:29 PM
Certified User
billjam's Avatar
Ha! Might be easier for you!!!
You are dealing with a real simpleton here when it comes to some of this electronic stuff. I have only got as far as I have with bulk assistance from you and others here.
The scope leads are plugged into the sensor connector and I have the oscilloscope pictured above, so playing around inside the ECU with a different type of scope isn't really an option right now.
It is all hooked up ready to measure, I just don't know how to setup the scope to show meaningful info.
I have already tried a few tooth logs. Isn't that is effectively capturing the signal from inside the ECU? This signal is erratic, that's why I need to get back to the source so I can be sure the sensor is OK.
Bill
2024 Macan S
Old 03-07-2015, 11:47 PM
MConn's Avatar
billjam,
Here's a picture of the speed and reference waveforms that i took from the ECU pins.
It's a lot of trouble to open the ECU to install the scope leads, but that way you are checking the wiring and sensors.
The sensor needs to be checked in-circuit because it's getting power from the ECU - you cannot unplug the sensor at the motor and connect the scope to the sensor.
Mike
The more I learn, the less I know.
Old 03-08-2015, 05:45 AM
Certified User
billjam's Avatar
Thanks Mike, but I didn't think that the 3.6 crank sensor was powered. I thought it just created its own pulses as the flywheel teeth passed by.
I can already check the output of sensor by running a tooth log in TunerStudio, but these logs are inconsistent, which is why I want to test the sensor directly without going through the ECU and wiring.
The way I read the manual instructions above, the sensor is being checked at the ECU connector with it disconnected from the ECU (otherwise you can't access the pins).
Bill
2024 Macan S
Old 03-08-2015, 06:22 AM
Diss Member
Quicksilver's Avatar
+1 ^
The sensor creates a power pulse and is unpowered. Disconnect from DME to test. When I went all oscilloscope on mine I pulled the plug at the DME and checked it there. If it is good there then you know the DME is getting good signal.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-08-2015, 08:04 AM
MConn's Avatar
I should have read your post closer. Sorry if I provided bad information. I must have cabin fever.
Mike
Old 03-08-2015, 08:07 AM
scarceller's Avatar
Trying to look at the signal during cranking is very difficult with a simple scope, you need a storage capable scope for that. If however the car will start and idles you should be able to see the signal with any scope.
If it's a no start issue you can quickly sanity check for signal at cranking with a 12vdc LED test light but it it MUST be a LED type. Walmart sells one in the auto section of the store for like $5.00 simply put the light across both pins and crank the motor and the light should flicker, if not something is wrong.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 03-08-2015, 01:57 PM
I would rather be driving
jpnovak's Avatar
Bill. The scope just has two connections. These will connect to the Reference sensor. Just put the ground lead on the sensor shield and the signal pin to the sensor. You can connect the sensor lead anywhere along the path between the sensor and the ECU. You might be able to pull back a connector and probe the crimped wire. Just find a place that is convenient.
You can crank the car with the scope connected. Change the Voltage scale such that the signal is on scale. Most likely you could start on a 25mV/div and come close. Then change the time scale such that you can see the full waveform. A good starting point would be 100ms scale.
You can watch the signal while cranking but as Sal said a storage scope is best.
Old 03-08-2015, 02:29 PM
Certified User
billjam's Avatar
I guess I owe you all an update. I haven't had time to look at the car for a couple of weeks, but managed to get home early today so I started from scratch again.
With the scope attached to the crank sensor's connector, with a bit of knob twirling it showed the following trace.
I have absolutely no idea what that represents, but when I cranked the engine, the trace changed to this ...
I don't know what that means either, but at least it showed that there was some action in the sensor circuit.
Bouyed by this, I moved the scope probes to the ECU end of the harness and got exactly the same trace.
So far so good!
Next step was to reconnect the ECU and try a tooth log again. Bugger me, it was a perfect log.
Then I tried test modes for spark and fuel and I could hear coils firing and injectors working exactly as they should.
Well the only step left now was to actually try and start the engine.
Sorry guys, it's getting late and I have an early start tomorrow, so I'll finish this tomorrow.
Bill
2024 Macan S
Old 03-19-2015, 05:54 AM
jpnovak's Avatar
Bill. The first oscillating wave in your scope looks like AC line voltage. Are you set for AC or DC trigger? Should be DC trigger. This should give you a flat line. This will allow you to resolve the second imposed wave in your second picture.
Your ECU trigger log looks good.
Now compare with the car running. I wonder if you are picking up EMI noise from one of your systems that prevents the car from running right.
Old 03-19-2015, 06:15 AM
scarceller's Avatar
What's the voltage scale set at in that first pic?
And what's the freq set at?
Would be helpful to know this.
Also is the first pic with the scope just connected? engine not turning at all? If so something is wrong, as Jamie pointed out you are most likely picking up 60 cycle noise?
Sal
1964 356SC (SOLD)
Old 03-19-2015, 06:33 AM
Diss Member
Originally Posted by billjam View Post
Hard to tell from the picture but it looks like the AC/DC select is extended in the AC position.
Old 03-19-2015, 07:20 AM
T77911S's Avatar
connect the ground connection on the O scope to the car ground. the body itself. its on the front of the scope next to ch2.
AC/DC on the ch should not matter. use AC though. that basically for setting a reference like if you wanted to measure a signal with reference to ground.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-19-2015, 09:30 AM
Certified User
billjam's Avatar
Thanks for your hints and suggestions guys.
1 volt and 10ms.
Yes, this is just with scope connected, engine not turning.
Before I got to the stage of rerunning the scope test of the crank sensor with different settings, I figured it was worth a try to see if the engine would start, as everything seemed in order ... except for my crappy scope operating skills!
Anyhow, it started up and ran fine, so whatever the original problem was, after all my fiddling with the innards of the ECU and disconnecting and reconnecting everything, I seemed to have fixed the problem.
Thanks again for your input, I guess we'll have to wait for another opportunity to turn me into a oscilloscope expert.
Bill
2024 Macan S
Old 03-22-2015, 06:23 AM
T77911S's Avatar
probably a bad connection.
RACE CAR:: sold
Old 03-23-2015, 04:47 AM
do you have the scope probe on terminals 1 and 2 (ground) of the sensor disconnected from the car?
Rick
88 Cab
Old 03-23-2015, 07:28 AM
Certified User
billjam's Avatar
Yes Rick. I was measuring the sensor output directly at the disconnected sensor connector pins 1 and 2.
Car is running fine now, just need to address poor cold starting and inop IACV and passenger electric window and oil leak and rattling gear linkage and slow puncture and torn headliner and body repaint and, well you get the picture!
Bill
2024 Macan S
Old 03-23-2015, 02:44 PM
fetus's Avatar
Are there any handheld oscilloscopes that can show the same thing?
75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts.
Old 09-29-2024, 08:56 AM
Navin Johnson
TimT's Avatar
Check out Seeed Studio
https://www.seeedstudio.com/DSO-Nano-v3.html
'69 911 GT-5
'75 914 GT-3
and others
Old 09-29-2024, 10:01 AM
