FYI, I hold a valid US Government EPA Federal "UNIVERSAL LICENSE", for ANY refrigerant or type of system Certification THAT encompass everything and is also recognized worldwide by all United Nations Signatories; NOT a lowly limited State technicians License The compressor used in THE BLACK SWAN is working absolutely perfectly as intended for optimal a/c cooling with the least amount of refrigerant with these pressures I posted using R134A as well as all of the components in the system! The evaporator is not freezing as well as the evap blower set on low speed and putting out vent temps in the mid-30s F, the PFC’s heat exchange for both is perfect, The thermal expansion valve has been modified and the superheat has been set perfectly. The system is working optimally for peak efficacy in perfect balance @ these pressures • What are HC-12aŽ and OZ-12Ž? HC-12aŽ and OZ-12Ž brand hydrocarbon refrigerant blends are flammable refrigerants. Their primary components are hydrocarbons, which are flammable substances such as propane and butane. HC-12aŽ and OZ-12Ž are registered trademarks of OZ Technology, Inc. HC-12aŽ has been marketed since 1994. OZ-12Ž was a similar blend marketed until the introduction of HC-12aŽ . Both products have been reviewed by EPA under the Significant New Alternatives Policy (SNAP) program. More information about the SNAP program is available from the hotline listed at the top of this page. Note that EPA refers to the chemical composition of HC-12aŽ as Hydrocarbon Blend B. EPA considers any substance with that chemical composition, no matter what its trade name is, to be Hydrocarbon Blend B and to have the same legal status that HC-12aŽ has. In order to meet Department of Transportation requirements for shipping HC-12aŽ in six-ounce cans (DOT refers to these cans as DOT 2Q containers), OZ Technology reduced the vapor pressure of HC-12aŽ in June, 1998 by changing the composition. EPA does not consider this reformulated HC-12aŽ to be the same as Hydrocarbon Blend B. The reformulated HC-12aŽ has not been submitted for SNAP review, and thus cannot be marketed or used as a substitute for ozone-depleting substances. • What is DURACOOL 12aŽ? Is there a difference between HC-12aŽ and DURACOOL 12aŽ? DURACOOL 12aŽ has the same chemical composition as the HC-12aŽ formulation that was submitted for SNAP review and was called Hydrocarbon Blend B. Both HC-12aŽ and DURACOOL 12aŽ are different than the new formulation of HC-12aŽ in six-ounce cans. DURACOOL 12aŽ is the registered trademark of Duracool Limited, the Canadian company that has manufactured DURACOOL 12aŽ since 1997. Duracool Limited and OZ Technology, the manufacturer of HC-12aŽ, are separate, unrelated companies with their own manufacturing facilities and distribution mechanisms. • What is the legal status of hydrocarbon refrigerants such as HC-12aŽ and DURACOOLŽ? It has been illegal since July 13, 1995 to replace CFC-12 with the HC-12aŽ formulation that was submitted for SNAP review in any refrigeration or A/C application other than industrial process refrigeration. The same prohibition for OZ-12Ž took effect on April 18, 1994. Because DURACOOL 12aŽ has the same chemical composition as the HC-12aŽ formulation that was submitted for SNAP review (i.e., Hydrocarbon Blend B), DURACOOL 12aŽ is also subject to the same restrictions. HC-12aŽ, as reformulated to meet DOT requirements, is not the same as Hydrocarbon Blend B and has not been submitted for SNAP review. OZ Technology is therefore prohibited from marketing this blend as a substitute for any ozone-depleting substance. In addition, any use of this blend as a substitute for CFC-12 or any other ozone-depleting chemical, in industrial process refrigeration or any other refrigeration or A/C end use, is prohibited under the Clean Air Act. Since HC-12aŽ, as submitted for SNAP review, is chemically different from HC-12aŽ, as reformulated to meet DOT requirements, and since it has a different legal status under the Clean Air Act, users of any substance marketed as HC-12aŽ should be aware of which HC-12aŽ they have purchased. Note: Many states prohibit using flammable refrigerants in motor vehicles, regardless of which original refrigerant was used in the vehicle. • May hydrocarbon refrigerants be used to replace CFC-12, commonly referred to as "FreonŽ ," in cars? No. It is illegal to use hydrocarbon refrigerants like HC-12aŽ and DURACOOL 12aŽ as substitutes for CFC-12 in automobile or truck air conditioning under any circumstances. Not a good IDEA, this refrigerant is flammable and can explode causing great injury or all kinds of damage, and why it is illegal to use in an automobile or truck Your thinking "A/C compressor won't last long though pulling a vacuum on the low side all the time. No oil flowing in the refrigerant and hard work on the compressor internals." IS SIMPLY WRONG! There will be no damage to the compressor as long as it has the right amount OIL in it and correct for the gas used, Last edited by KelogGes; 04-08-2015 at 11:08 PM.. |
Banned
No wonder he's only using .95 pounds, 3/4 of the system is sealed off with that lifting arm! I'm still trying to figure out how you "invented" the reversed gas flow 2 years ago, yet my car and every car with the underbelly condenser has the reversed gas flow already, dating back 10 years or more.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
This is a serious thread
If you can't act like an adult Leave!!! |
look closer the hoses are not crushed
Fleabit peanut monkey
You don't quite get it.
You are the a-hole here, Slick.
1981 911SC Targa |
Please close this thread.
Somebody?
1981 911SC Targa |
belly-pan condenses have an extremely poor heat exchange for several reasons this is why they are no longer produced
They have nothing to do with this tread |
Bwa-ha-ha-ha It's funny, the more boisterous the enema bag (that's you, KelogGES) the more they are unable to communicate using the standard format and rules English speaking people have adopted.
1981 911SC Targa |
El Duderino
Faux intellectualism. Gotta love it...
So you're lifting the car via the sway bar? Even better!
It doesn't matter whether underbelly condensers work well or not (they do), it matters that you claim to have invented a new way to flow the gas in a Porsche A/C system, when facts show that you did NOT invent it. That's all, nothing more.
I assume that he removes all of the gasoline from his cars before driving as well, since it's flammable and can explode causing great injury
Joke was that you are either injured OR property damage occurs - but not both injury and damage. I have to articulate that or I will be blamed as a fire starter first and then KG will "ig" me even more.
1981 911SC Targa |
1981 911SC Targa |
I AM NO FOOL!!!
its going to be fun proving ALL the NA Sayers wrong shortly that have dogged me for over 4 years |
1981 911SC Targa |
arrangement and then insist that's it's actually an improvement over the factory system. The true test of an A/C system is how fast it can bring down an overheated cabin atmosphere to a sensible human comfort level, not how cold the outflow might be with minimum airflow once the cabin is comfortable. |
You are talking the widely accepted Ronnie comfort plus 22F rule, correct? (Or was that plus 40F?)
1981 911SC Targa Last edited by Bob Kontak; 04-09-2015 at 09:31 AM.. |
Banned
Riiiiiggggghhhhhtttttt! My a/c comfort zone would have Will reaching for the nearest space blanket (like Saul's brother in "Better Call Saul" - though he isn't doing it for warmth). |
