3 restos WIP = psycho
Ronknees a lot of things... But a liar??? Come on dude.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Banned
^^^^ Ha! Hilarious - bet some of the folks here in the "non-turbo-911" forum are wondering about that "Ronknees" reference!
And watch it, bro, or I just might assemble a "party kit" picture post with your name on it . . . instead of Paul's!!!
LOL! Back to the regularly scheduled broadcast...
But they do represent a practical impossibility. Would you put a glass water in your freezer and expect it not to freeze...? Yes, your freezer produces a lot more COLD but the physics are the same. It might take a long time but on a hot and humid day such as is often encountered in your area an evaporator operating at sub-freezing levels WILL FREEZE UP! There is a solution, one that most heat pumps operating in space heating mode use. They use 2 heat sensing elements. One of those elements(A) is located nearest to the point on the EVAPORATER/(condenser) that is expected to freeze initially, near the TXV outlet, say. The other(B) is located mid-point in the EVAPORATOR/(condenser). As the EVAPORATOR/(condenser) CHILLS both sensors will indicate a declining temperature. Ice will act as a insulate, so, once the sensor near the inlet(A) stops falling in temperature vs the mid-point sensor, ice has begun to form around and the EVAPORATOR/(condenser) must be put through a reverse cycle, DEFROST the EVAPORATOR/(condenser). If you even have a chance to see one in operation, during the relatively brief reverse/defrost cycle, it looks as if the heat pump has caught fire, heavy plumes of vapor rising into he air. This is what bothers me about Charlie's refrigerant charge method, change to get the lowest possible vent temps, oftentimes sub-freezing temperatures. But. That would mean that the thermostatic control switch MUST be tightly calibrated. Calibrated such that on the average evaporator operating temperature must be above 32dF. So now you have a significantly undercharged system that is not fully capable of combating a full heat load. |
You could squelch me by simply supplying before and after data indicating your reverse flow technique yields an improvement in our factory A/C performance. You keep suggesting that some interested DIY'er try it in order to prove YOU correct. But most DIY'er are bright enough to see the illogic in your idea. Now that's true BS! |
kenikh I don't generally call someone this but in this case I felt it appropriate and warranted On An automobile this is impossible He kept repeatedly showing a handheld gun showing this, said repeatedly his a/c system does not freeze up at all at, with air vents he shows a hand gun showing this 29 degree temperature and states he does this for long periods of time This is A LIE on earth this is thermodynamically impossible without freezing up the evaporator and stopping function under the laws of thermodynamics Last edited by KelogGes; 04-11-2015 at 10:26 PM.. |
Dave, you need to look back at the blower picture he represented that he used in the initial "reverse the gasses" work. |
Banned
29 degree vent temps and no freezing up is a lie
Ok, NOW I see why you question Ronnie's claims. Your explanation of why helped me understand but why call him a liar? To me, that is just the wrong tactic to take in trying to convince a group that your way is better.
I don't mean to sound like Dr.Phil. Obviously, you are passionate about your work and that's good. I'm stepping out of the thread. I wish you the best.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Solar Impulse 2 Airplane First Flight - Maiden Flight
The TAN SWAN
![]() The BLACK SWAN ![]() ![]() ![]() R134A 0.95 lbs of refrigerant total used ![]() ![]() PROVEN TRUTH !!! Last edited by KelogGes; 04-12-2015 at 08:27 AM.. |
Speaking of sub-freezing temperatures....
You still haven't explained those negative PSI readings on the suction side along with decent high side PSI indications. I've explained how sub-freezing vent temperature "snapshot" guage readings can be had without anyone lying... Your turn...
Banned
That's hubris & envy working away at Reid's delicate ego. I've demonstrated that his many years worth of boasts about superior products and methods, and his bashings of obsolete technologies and ideas, are unfounded, and his reaction to said exposure is to lash out.
Prove Me Wrong
NO! We're going to take it for granted that you're the one wrong since there is no existing logic to warrant a DIY'ers, or anyone's research into your invention.
Why not a start.. Explain why you think your "reverse the flow" idea will improve the A/C performance of our A/C systems. |
Archimedes UNDERSTOOD what made the water rise in his bath....
Do you UNDERSTAND why your idea would improve our A/C..?? |
I agree that we need credibility for the Reverse idea. I really don't care WHY anyone thinks it should or shouldn't work better than stock. Reid had an idea, he tested it, and thought it worked very well. I wish Reid would provide some of his observations on cooling performance on the day he first tried the idea. He must have seen lower pressures or lower vent temps or something. I'm the kind of guy who drives around with a thermometer in my a/c vent. I know when something is wrong. I bet he saw something that made him think he had found an improvement. He may not know why it works. If it really works, we can figure out why later. Either way. He says it works, so either take him at his word and try it. Maybe it will work. Remember, it might not work, and that's the risk you take.
Take care, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT Last edited by DaveMcKenz; 04-12-2015 at 10:52 AM.. |
Thanks Dave as always for YOUR open minded insight
