roflmaO
This has never been done by Porsche or anyone else for that matter with this new way THE gases always went to the rear first than the front UNTIL I DISCOVERED THIS FLAW AND REVERSAL OF THE GASES Believe it or not the hose length is about the same KINDA REMEMBER I AM NOT SPOON FEADING YOU REGARDING THIS Last edited by KelogGes; 03-29-2015 at 11:03 AM.. |
Thanks for attempting to think out of the box despite the fact what you describe is merely changing the sequence of which condenser first receives heat-laden freon and not really reversing the refrigerant path through the system.
Imagine a true flow reversal where the high pressure side of the compressor (red) redirects to the evaporator but whose flow is restricted by the downstream expansion valve. A rupture in the former low pressure (blue), now high pressure line is inevitable. Uh uh. ![]() The system would work most efficiently if there were only one condenser (as pictured), but in the front and with a high capacity to transfer max. heat, enough to eliminate the need for an engine-mount condenser. It is this condenser that unnecessarily contributes to heat load. It is there only because it's in an available space with air flow. Sherwood |
Fleabit peanut monkey
Issac Newton actually became reclusive when folks beat the crap out of some of his ideas.
No risk of that here given your pompousness.
1981 911SC Targa |
Your Mom tells me the same thing.
1981 911SC Targa Last edited by Bob Kontak; 03-29-2015 at 01:41 PM.. |
Banned
Best friend is my dog
BINGO!!! You also win a KEWPIE DOLL AND A GOLD STAR! You weren't the first to figure this out from the SimpleTON clues he gave
El Duderino
Whatever you do, don't cross the streams!
Banned
Stream control is very important (note the "outside the box" skill displayed below)!
It's OK guys.
It turns out it is reversal of condenser order. He wanted to present a riddle, so he said reversal of gases to add a little mystery. It's either a good idea or it's not. Reid claims it works well. I can see an advantage, but also more hose length. Anyone want to try it, then you can confirm or deny his layout superiority. Until then we'll just have to guess, or take Reid at his word. Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT Last edited by DaveMcKenz; 03-29-2015 at 03:22 PM.. |
Chain fence eating turbo
Yeah, someone do this already and report back.
![]() One day, gonna put AC in mine. |
You seem to be almost the only one here that thinks WITH THEIR BRAIN, Thanks for taking the time and effort to learn. You WILL DEFINITELY, SEE AN ADVANTAGE WHEN YOU TRY IT! Time will tell as you figure it out! I am not leading you on a path of BS, I would not do that to anyone! Instead of of all those opening their mouth to disrupt AND BS! IT FOR SURE WORKS, and even works better with my PFC's, but my PFC's work so well it won't hurt me to give it to the world as a Gift! I have a well known Porsche repair shop near me that LOVES THIS modification after I did it on one of this client 911's after which I did this on another one of his clients 911's that was even more complicated, and proved it to him and its a major selling point now for him and has has done several other 911 with very happy clients over this; he is not going to be too happy probably about me giving this to the world! But ITS MINE TO GIVE I discovered it on my own and proved it to myself in the middle of the night and I only gave it to him to use! GIVE THIS INFO TO ANY early model 911 owner that has OEM A/C and he will sincerely thank you the moment he try's this As this new 911 A/C GIFT from my heart spreads through out the world I know I will be remembered for doing something nice that affects others The Nay Sayers in this tread and on this topic for whatever reason have to be the stupidest people in the world when given a TRUE GIFT FOR FREE, THEIR stupidity is really fun to watch from my perspective LoL Last edited by KelogGes; 03-30-2015 at 07:20 AM.. |
Banned
And to think you have the nerve to call other people "slow & stupid"! Last edited by Ronnie's.930; 03-29-2015 at 04:26 PM.. |
Okay, now I understand. I was not fully aware of the sequencing of condensers. Also, your terminology was a little too cryptic.
I think that the factory routing was an attempt to keep high-delta-T's; this generally results in greater heat transfer. The high temperature gas is cooled by the engine compartment condenser with medium air temperatures. Then the medium temperature gas is cooled by the front condenser with low temperature air. Theoretically this would result in lower final liquid gas temperature. However, when theory meets reality, then things can change. If the front condenser now does almost all of the cooling, then the rear condenser may even be a liability. I would carefully check inlet and outlet temperatures on the rear condenser to ensure it is still contributing to the cooling; it may not be, and in that case should be removed.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
First routing the HOT gas to the front lip condenser and then to the rear lid condenser leaves us with the EXACT same overall refrigerant condensing capability. Plus, isn't the total surface area for heat transfer a lot lower for the front lip condenser?
Net negative for A/C..?? My conclusion is that the only advantage is less heat load to/on the engine. It seems to me that making use of the cabin heat blower not only increases the efficiency of the rear lid condenser substantively, and only when/as needed, but is also as aid to cooling the engine via the extraction of heat from the exhaust manifold as is done with the 964/993 series. Last edited by wwest; 03-29-2015 at 04:59 PM.. |
