-   -   A/C Reverse The Gases in Early Model 911's (http://forums.pelicanparts.com/porsche-911-technical-forum/858116-c-reverse-gases-early-model-911s.html)
KelogGes 04-13-2015 08:41 AM
wwest the clueless wonder of the fan mentality that knows nothing about gases and heat exchange
Algernon 04-13-2015 09:51 AM
I also used to think wwest was the most clueless wonder of AC theory. But now KelogGes and your idiotic and evasive posts have easily achieved the number one position, and by comparison, wwest is actually making some sense.
http://forums.pelicanparts.com/uploa...1428943819.jpg
KelogGes 04-13-2015 10:17 AM
Algernon glad he is making sense TO YOU!
ROFLMAO
wwest 04-13-2015 10:28 AM
ROFLMAO
KelogGes, I have long known, acknowledged and accepted, that sound logic is well outside your purview.
Your PFC itself has a sound logic basis but you have now wandered to far afield.
What your PFC idea needed was to be coupled with some type of additional cooling airflow, which only now you seem to be ready to address.
The CFM rating of that Spal blower is meaningless with the existing restrictions both on the inflow side and the outflow.
DaveMcKenz 04-13-2015 10:36 AM
Hi Wwest,
I agree with you about airflow, as you know. I looked at the design of Reid's front cooling shroud. I see the small holes, and I was confused. The holes may be an attempt to get airflow over the whole surface of his front condenser. They may be like the multiple holes on a shower head. He gives up some total flow for uniform air distribution. I am not sure, but that may be his thought.
Dave
Ronnie's.930 04-13-2015 10:41 AM
No doubt about his well earned, #1 status, and in fact, Reid is a "double title holder" here; #1 in both cluelessness and bullshattery.
PS- that cluepon is hilarious, but I think ol' Reid will need about 50 of them in order to raise his clue index by even 1/2 a point!
KelogGes 04-13-2015 11:06 AM
Originally Posted by davemckenz (Post 8574702)
hi wwest,
i agree with you about airflow, as you know. I looked at the design of reid's front cooling shroud. I see the small holes, and i was confused. The holes may be an attempt to get airflow over the whole surface of his front condenser. They may be like the multiple holes on a shower head. He gives up some total flow for uniform air distribution. I am not sure, but that may be his thought.
Dave
balance
you can't see the rest of the design on purpose
lol
Tippy 04-13-2015 12:40 PM
I actually think KelogGes is on to something with the microchannel stuff.
But, you can buy those off ebay for $55 each. I know it's curved and all, but.........just saying.
wwest 04-13-2015 12:48 PM
Originally Posted by KelogGes (Post 8574756)
balance
lol
We can see enough, to much, really, of your air flow manifold design to easily surmise its idiocy.
Bottom/sides completely covered over, no roadspeed cooling airflow. Not that your PFC design would allow for that in any case.
wwest 04-13-2015 12:59 PM
If you're going to "meter" airflow at the top, inflow, then why close off the bottom?
Like I said, design IDIOCY!
crownarch 04-13-2015 01:35 PM
I asked him basically the same question way back in post 313 and he never answered. And, he is not going to because in his brain everyone around him is a fool. Exception.......himself, but only in his mind. I guess too many days out in the hot Florida sun.
KelogGes 04-13-2015 01:51 PM
dream on
KelogGes 04-13-2015 03:47 PM
crownarch I am not sure if I want to make or market this particular interior of this shroud, it is very complex multi-part construction sandwich
it worked good, but i think the design could be much better and ever far more efficient across the coil
I want to talk to other engineers about it in the future
KelogGes 04-13-2015 05:18 PM
Howdy Tipppy
Micro-channel parallel flow since invented in Japan 2003 has completely taken over all other forms of heat exchanger technologies around the world
Its why I can use ONLY 2 state of the art PFC's less than 1 inch thick and extremely lightweight in the original OEM placement areas on early model 911's and with a tweaked A/C system get the low air vent temps using less than ONE lb of R134A refrigerant I get
Why anyone would use an older technology heat exchanger and need to run 3 much heaver and larger heat exhangers is beyond me?
PFC heat exchanger technology is approximately 30-35 Percent or more, more efficient exchanging HEAT, and a PFC also has the ADDITIONAL ability to be 25-36 percent smaller in surface areas dimension size and yet still BE 30 to 35 percent more efficient
THESE ARE FACTS LOOK THEM UP
Porsche as well as every other automobile manufacture all switched to PFC a few years ago and never looked back.
OH almost forgot
Each year since discovery of PFMC heat exchangers there effiency has gone up higher to the leveal of state of the art it is today
People that cling to Serpentine technology today are CHASING OBSOLESCENCE
KelogGes 04-13-2015 05:39 PM
what you have seen on eBay IS cheap china knock off junk and/or and its old technology ; you get what you pay for LOL
Buy it if you want too
But it does NOT fit an early model 911 deck lid properly, its also way to small
As far as I know I am the only person custom making PFC's designed specifically for early model 911's using state of the art technology front and rear
other companies selling PFC's for 911's are mostly re-selling Arizona Mobile Air, Inc. | Automotive Air Conditioning Parts & Equipment china universal crap,
they only have a kinda sorta a rear one that does not really fit correctly that have air gaps on the sides you can drive a bus through LoL
but this one is actually better than an OEM Behr that used tube and fin technology,
RennAire Porsche 911 Air Conditioning Products
sells them after I refused to give him an exclusive on my PFC's after he tested a set made for him of my designs, he liked them VERY MUCH and wanted to buy them
oh and so as does another a/c aftermarket 911 company I forget their name sell Arizona Mobile Air, Inc. | Automotive Air Conditioning Parts & Equipment FOR 2-3 Times what you can them direct from Arizona Mobile Air, Inc. | Automotive Air Conditioning Parts & Equipment yourself
Ya want one I still have a test one I bought from Arizona Mobile Air, Inc. | Automotive Air Conditioning Parts & Equipment to test it right before I started making my own because I could not buy what I wanted and this is what led me to make my own using state of the art technology make me a cheap offer, it slightly used for about a month for testing
good luck finding a pfc that will fit in front
other than mine, they don't exist,
to the best of my knowledge
Tippy 04-13-2015 06:24 PM
Thanks for the offer Reid, but I'm really far away from having a complete AC system.
I do wish you luck on getting to market, but at a reasonable price. I'm game for lightweight, efficient AC. I believe I read the entire AC system of an older Lotus Elise was 35lbs. I could live with that!!
86 911 Targa 04-13-2015 06:31 PM
Boyle's Law.
https://www.google.com/search?sourceid=navclient&aq=&oq=boyle%27s+law&ie= UTF-8&rlz=1T4GUEA_enUS570US570&q=boyle%27s+law&gs_l=hp ...0l5.0.0.0.4085...........0.y7IIfsOvioA
Let's give this some thought.............
DaveMcKenz 04-13-2015 06:45 PM
What exactly is your point?
Dave
KelogGes 04-13-2015 06:51 PM
? why
BTW: My sister lives in Manhattan beach
DaveMcKenz 04-13-2015 06:55 PM
BTW Boyle's Law is important in refrigeration, but the action of condensable gases and phase change are probably even more important.
Dave
