-   -   A/C Reverse The Gases in Early Model 911's (http://forums.pelicanparts.com/porsche-911-technical-forum/858116-c-reverse-gases-early-model-911s.html)
KelogGes 04-13-2015 07:09 PM
Originally Posted by Tippy (Post 8575393)
Thanks for the offer Reid, but I'm really far away from having a complete AC system.
I do wish you luck on getting to market, but at a reasonable price. I'm game for lightweight, efficient AC. I believe I read the entire AC system of an older Lotus Elise was 35lbs. I could live with that!!
Thanks, I will have an announcement very soon about something I am doing for a DIY
Anyway are you putting or have plans to install into your 930?
That weight is low which is good but what about the condenser size surface are dimensions
930/s with large enter-coolers reallly cut down a/c system heat exchangers room
and makes it even more of a challenge to make cold a/c
Tippy 04-13-2015 07:13 PM
I have a turbocharged Carrera 3.2 still narrow body.
But yes, my intercooler is full bay (width).
Tippy 04-13-2015 07:19 PM
I just meant, I remember reading the Lotus Elise AC system was designed super lightweight, not that I'd use one.
KelogGes 04-13-2015 07:44 PM
Thanks didn't see that until I got to the reply edit window
Anyway that makes things HARDER BUT not impossible, although I have not installed one yet I have A small PFC for 930s 1/2 upper deck lid space, and you would still need my front PFC
But why would you want to put in a lotus a/c system? or chaNge from Porsche's 911 design?
not sure if that would work for you but it might?
crownarch 04-13-2015 07:49 PM
I agree with you KelogGes, new AC systems/components are becoming super light weight and extremely compact. Not to change your thread but, the compressor on a brand new Scion FRS is not much bigger than a coffee cup. In addition, there is not much to their condensers. That's what is great about new technology as it is always in constant change for the better.
KelogGes 04-13-2015 07:57 PM
OH ok
YOU need to use your smugglers box for evaporator
OEM plastic box is designed to fit it then it can be modified
you dont want to make an abortion a/c
The Tan Swan the Father that first had because he lived in pacific nothwest and you don't need a/c there hacked the firewall and the duct-work under the dash to put in a 12 volt heater and tossed out the a/c
What a friggen pain his hack job caused and a lot of labor to fix it, The Tan swan took months of work ouch
but now it has a state of the art new technology A/C system in it all custom designed
Tippy 04-13-2015 08:08 PM
Gears turning.....
Tippy 04-13-2015 08:09 PM
<!-- BEGIN TEMPLATE: bbcode_quote -->
<div class="pre-quote">
Quote de <strong>Tippy</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">I just meant, I remember reading the Lotus Elise AC system was designed super lightweight, not that I'd use one.</div>
</div>
<!-- END TEMPLATE: bbcode_quote -->OH ok<br>
<br>
YOU need to use your smugglers box for evaporator <br>
OEM plastic box is designed to fit it then it can be modifed <br>
<br>
you dont want to make an abortion a/c <br>
<br>
<br>
The Tan Swan the Father that first had because he lived in pacific nothwestt and you don't need a/c there hacked the firewall and the duckwork under the dash to put in a 12 volt heater and tossed out the a/c<br>
<br>
What a friggen pain his hack job caused and a lot of labor to fix it, The Tan swan took months of work ouch<br>
<br>
My car is a bastard, fully understand!
wwest 04-13-2015 08:40 PM
Originally Posted by KelogGes (Post 8575320)
what you have seen on eBay IS cheap china knock off junk and/or and its old technology ; you get what you pay for LOL
Buy it if you want too
But it does NOT fit an early model 911 deck lid properly, its also way to small
As far as I know I am the only person custom making PFC's designed specifically for early model 911's using state of the art technology front and rear
other companies selling PFC's for 911's are mostly re-selling Arizona Mobile Air, Inc. | Automotive Air Conditioning Parts & Equipment china universal crap,
they only have a kinda sorta a rear one that does not really fit correctly that have air gaps on the sides you can drive a bus through LoL
but this one is actually better than an OEM Behr that used tube and fin technology,
RennAire Porsche 911 Air Conditioning Products
sells them after I refused to give him an exclusive on my PFC's after he tested a set made for him of my designs, he liked them VERY MUCH and wanted to buy them
oh and so as does another a/c aftermarket 911 company I forget their name sell Arizona Mobile Air, Inc. | Automotive Air Conditioning Parts & Equipment FOR 2-3 Times what you can them direct from Arizona Mobile Air, Inc. | Automotive Air Conditioning Parts & Equipment yourself
Ya want one I still have a test one I bought from Arizona Mobile Air, Inc. | Automotive Air Conditioning Parts & Equipment to test it right before I started making my own because I could not buy what I wanted and this is what led me to make my own using state of the art technology make me a cheap offer, it slightly used for about a month for testing
good luck finding a pfc that will fit in front
Well stated...
other than mine, they don't exist,
What good is the FIT, if the FUNCTION is lost...???
to the best of my knowledge
An "edge forward" mounted PFC has little or no functionality insofar as airflow cooling from forward roadspeed, whereas the factory condenser gains >80% of its function that way.
Perhaps that's why KelogGes is making such a concerted effort to cool it electrically.
22 amps...
KelogGes 04-13-2015 08:57 PM
thanks i didnt know
KelogGes 04-13-2015 09:00 PM
Originally Posted by Tippy (Post 8575557)
Gears turning.....
some is good others are crap
you have to be careful
Ronnie's.930 04-13-2015 09:37 PM
Will this actually increase 911 a/c performance past what is already widely available - not just weight savings but actual cabin cooling performance? Nothing that you have shown-&-told thus far (over and over and over and over) has accomplished this, so maybe this "to be announced" product/idea will get you there.
SilberUrS6 04-13-2015 09:47 PM
Originally Posted by KelogGes (Post 8574510)
wwest the clueless wonder of the fan mentality that knows nothing about gases and heat exchange
This is the single most ironic thing I've read on Pelican Parts.
Ronnie's.930 04-13-2015 10:34 PM
Definitely a fine example of this, right?!?! :D
http://forums.pelicanparts.com/uploa...1428989693.jpg
KelogGes 04-14-2015 05:53 AM
I CALLED YOU A LIAR
li·ar
ˈlī(ə)r/
noun
a person who tells lies.
synonyms: deceiver, fibber, perjurer, false witness, fabricator, equivocator; fabulist;
And I meant it and still maintain you are !
for the BS you posted here repeatedly about your car A/C system and claims is true posting so called temperature numbers pictures showing 29.x degrees and saying your evaporator does not freeze up, and the rest you said about extended driving at these temperatures
I AM CALLING YOU OUT
KelogGes 04-14-2015 06:21 AM
I have never posted anything but true facts here I can back up with proof !
KelogGes 04-14-2015 07:46 AM
Prove me wrong
KelogGes 04-14-2015 09:26 AM
22 amps...
roflmaO
wwest 04-14-2015 09:45 AM
Originally Posted by KelogGes (Post 8576276)
roflmaO
So, a simple task...
Give us a line drawing of how you propose that roadspeed forward motion airflow cools your PFC as well as would the factory tube/fin one.
KelogGes 04-14-2015 10:08 AM
in your case
you can't fix stupid!
