-   -   A/C Reverse The Gases in Early Model 911's (http://forums.pelicanparts.com/porsche-911-technical-forum/858116-c-reverse-gases-early-model-911s.html)
KelogGes 04-14-2015 01:13 PM
Back to reversing the gases on an early model 911
KelogGes 04-14-2015 01:14 PM
I have made a set of PFC's for a DIY'er They Will Be Installed Reversing The Gases
I have made a matched set of PFC's for a DIY'er
They Will Be Installed BY The Owner "Reversing The Gases"
West Coast 86 Carrera Cabriolet DIY owner
wwest 04-14-2015 01:39 PM
Excellent!
Why not have your DIY'er first install your PFC's without the reverse aspect, take some data, and then convert to reverse flow and supply you with comparison data sets?
Validation of your "invention".
Put the fire to the feet of all us "naysayers".
wwest 04-14-2015 01:41 PM
What? No simple drawing of airflow against the flat leading edge of you horizontally mounted PFC?
wwest 04-14-2015 01:59 PM
Drag coefficient - Wikipedia, the free encyclopedia
http://forums.pelicanparts.com/uploa...1429045107.jpg
KelogGes 04-14-2015 03:07 PM
nothing for YOU
KelogGes 04-14-2015 03:14 PM
in your case
you can't fix/help stupid!
Ronnie's.930 04-14-2015 03:31 PM
Originally Posted by KelogGes (Post 8575947)
I have never posted anything but true facts here I can back up with proof !
Yep, you've posted proof that your creations perform ALMOST as good as the long-used, 911 a/c upgrades which are available without all of the smoke-&-mirrors nonsense associated with yours.
Originally Posted by KelogGes (Post 8576097)
Prove me wrong
Again? Wow, you're definitely a glutton for punishment!
KelogGes 04-14-2015 03:55 PM
Reversing the Gases
something old
http://forums.pelicanparts.com/uploa...1429051147.jpg
http://forums.pelicanparts.com/uploa...1429051921.jpg
something Brand NEW
KelogGes 04-14-2015 04:16 PM
and you are definitely a LIAR
I can take the punishment can you?
KelogGes 04-14-2015 04:24 PM
maybe its time to start trolling you and your 5,994 Posts: around daily calling you a LIAR
the way you have done me,
except I have never lied BUT YOU HAVE
Ronnie's.930 04-14-2015 04:29 PM
If you call under 30 degrees vent temperatures in 98 ambient, resulting in interior temps that you could safely transport meat in, "punishment", then yes, I'll take all the punishment I can get!
I won't have a problem with that since the only person on the forums that questions my honesty is YOU, and we all know how little credibility you have when it comes to Porsche 911 a/c.
When did I call you a liar? I have repeatedly pointed out that your a/c creations and ideas do not outperform the well established upgrades that people use (what you call "obsolete"), and in fact, barely equal some I have seen and work less well than others. This observation is based on the evidence that you have provided. How is that "calling you a liar"?
KelogGes 04-14-2015 05:06 PM
Bs
you are a liar!
Originally Posted by ronnie's.930 (Post 8576989)
if you call under 30 degrees vent temperatures in 98 ambient, resulting in interior temps that you could safely transport meat in, "punishment", then yes, i'll take all the punishment i can get!
I won't have a problem with that since the only person on the forums that questions my honesty is you, and we all know how little credibility you have when it comes to porsche 911 a/c.
When did i call you a liar? I have repeatedly pointed out that your a/c creations and ideas do not outperform the well established upgrades that people use (what you call "obsolete"), and in fact, barely equal some i have seen and work less well than others. This observation is based on the evidence that you have provided. How is that "calling you a liar"?
wwest 04-14-2015 06:38 PM
Originally Posted by KelogGes (Post 8577048)
Bs
you are a liar!
when you begin to think everyone else is crazy......
Bob Kontak 04-14-2015 06:54 PM
Bs
you are a liar!
Ronnie's numbers on the infrared were true. A man with a 1" chubb (stiffy mode) does not lie. What does he really have to live for?
However, pull the car out of the 80 F shade into 95 F and start cooking the car and the whole dynamic will change to where his system works. I don't see that as lying.
SilberUrS6 04-14-2015 06:57 PM
Originally Posted by KelogGes (Post 8576361)
in your case
you can't fix stupid!
The second most ironic thing I've read on Pelican Parts.
Ronnie's.930 04-14-2015 07:15 PM
urmom has never complained!!! :D
Mark at Pelican Parts 04-15-2015 09:50 AM
Again folks, if we can turn this thread around to a tolerable tone without harassment then we'll keep it alive. If we continue down this path, we'll shut it down.
Honestly, I'd like to see it play out - up to you.
wwest 04-15-2015 10:26 AM
This thread is well beyond being creative so I think most of us would just as soon see it closed.
I suggest that once KelogGes has real, actual, results to provide, and/or decides to widely market his "inventions", that he then open a new thread.
On the other there is entertainment value...
KelogGes 04-15-2015 11:11 AM
Thank You Mark
