Back to reversing the gases on an early model 911
I have made a matched set of PFC's for a DIY'er
They Will Be Installed BY The Owner "Reversing The Gases" West Coast 86 Carrera Cabriolet DIY owner |
Why not have your DIY'er first install your PFC's without the reverse aspect, take some data, and then convert to reverse flow and supply you with comparison data sets? Validation of your "invention". Put the fire to the feet of all us "naysayers". |
in your case
you can't fix/help stupid! Last edited by KelogGes; 04-14-2015 at 02:17 PM.. |
Banned
Again? Wow, you're definitely a glutton for punishment! |
something old
![]() ![]() something Brand NEW Last edited by KelogGes; 04-14-2015 at 03:10 PM.. |
I can take the punishment can you? |
maybe its time to start trolling you and your 5,994 Posts: around daily calling you a LIAR
the way you have done me, except I have never lied BUT YOU HAVE |
Banned
If you call under 30 degrees vent temperatures in 98 ambient, resulting in interior temps that you could safely transport meat in, "punishment", then yes, I'll take all the punishment I can get!
When did I call you a liar? I have repeatedly pointed out that your a/c creations and ideas do not outperform the well established upgrades that people use (what you call "obsolete"), and in fact, barely equal some I have seen and work less well than others. This observation is based on the evidence that you have provided. How is that "calling you a liar"? Last edited by Ronnie's.930; 04-14-2015 at 03:35 PM.. |
Bs
you are a liar! Quote:
Fleabit peanut monkey
Ronnie's numbers on the infrared were true. A man with a 1" chubb (stiffy mode) does not lie. What does he really have to live for?
However, pull the car out of the 80 F shade into 95 F and start cooking the car and the whole dynamic will change to where his system works. I don't see that as lying.
1981 911SC Targa |
Banned
Banned
Again folks, if we can turn this thread around to a tolerable tone without harassment then we'll keep it alive. If we continue down this path, we'll shut it down.
Honestly, I'd like to see it play out - up to you. Mark at Pelican Parts |
I suggest that once KelogGes has real, actual, results to provide, and/or decides to widely market his "inventions", that he then open a new thread. On the other there is entertainment value... |
Thank You Mark
