Reversing The Gases
My PFC's Are Real and are better then any other solution for making an early model 911 COLD |
Um...I think that EVERY MANUFACTURE (sic) IN THE WORLD just just that.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
I'm waiting for you to admit that you didn't invent the "reverse gas flow". Go on, it's OK, we'll wait.
Banned
Banned
Fleabit peanut monkey
Is this out of line with the norm? I never have heard an owner of a stock system in the years you are talking say "Damn, my evaporator keeps freezing up on me" Not taking sides - just saying what I see.
1981 911SC Targa |
Originally Posted by KelogGes
DUH ok rofl prove it and market it here on Pelican Parts its time people see right through you AND YOUR BS! Quote:
All my testing has been verified
Banned
Banned
You have not demonstrated anything here that equals my custom system (similar to what many other people are running), utilizing a combination of serpentine and tube & fin heat exchanges, much less surpasses it in performance. Quote:
Exactly! Last edited by Ronnie's.930; 04-15-2015 at 09:21 PM.. |
May just look at porn for a while.
1981 911SC Targa |
Bob, since when can a factory A/C system, fully operational, not meet KelogGes' above stated criteria? 30dF vent temps with OAT at 95dF, or even higher, is easily done with a factory system, at least the one in my '88, and I expect the '78 that I sold. On the other hand, I do not subscribe to the idea of undercharging the A/C system in order to get vent temps, I think the system needs a full refrigerant charge to best handle a full heat load and pull the cabin temp down to a reasonable comfort level, ~75dF, quickest. And I admit that I am growing tired of seeing these low vent temps quoted absent disclosure of the system inlet temperature. OAT is important to the overall equation but with without knowing the system inlet temperature that bit of information is useless. It only takes about 20-30 minutes "at speed" over on the Wa dry side, HOT side, for my '88 to get vent temperatures in the range KelogGes quotes. But even in our LS400, or the RX300, I am of the habit of turning the system to max cooling (or heat in winter), and then moderating the setting the airflow or air temperature begins to be discomforting. Last edited by wwest; 04-15-2015 at 09:26 PM.. |
Banned
Not a single person who posts in these threads has said, or implied, this except you, Reid. The issue here is that you claim that the micro-channel gear that you make vastly outperforms other options in 911 a/c applications, and the evidence you have provided does not support your claim.
Banned
Banned
^^^ Sorry, but this is just plain silly. Last edited by Ronnie's.930; 04-15-2015 at 09:41 PM.. |
The moderators are watching this thread
The only thing I see is harassment over and over coming from the same people |
Banned
Well, not really. If the inlet temp is 150*F and the outlet temp is 28*F, you have done some serious work.
If the inlet temp is 40*F and the outlet temp is 28*F, you're not doing much of anything. While wwest might think he has scored some points there, he hasn't. Folks dont't run the AC in their garage in a closed car for an hour before showing vent temps. They are doing this stuff with the car doors open, during the charging and testing phase of the process. When people say what the climatic conditions are at the time of the test, they are giving a rough idea of what the inlet temp is. yes, over some time, you can get the cabin down to 60*F and nearly zero humidity. And then you can crank the thing up and get 23*F vent temps. But nobody is doing it like this, so its a bogus question.
A wolf pack with an agenda ONLY to harass IN The Pelican AlC Forums IS What you have
Anyhoo, I am a little confused given the fight discseven had to get his vent temps into the 30's that a stock SC can pull 30F vent temps as normal. He did have a 3.2 - but not a later one, maybe an 85? Just my limited experience. Not wanting to wrestle one bit.
1981 911SC Targa |
