Bill Verburg's Avatar
Originally Posted by Shaun 84 Targa View Post
245s fit on 8s perfectly fine.
They may fit but for maximum performance potential you want them on 9s
Bill Verburg
Old 04-21-2015, 09:05 AM
Originally Posted by daleflesburg View Post
I am using 205 55 16s on 8 inch rims and 225 50 16s on 9 inch rims. I personally like the look of a wheel rim that is as wide as the tire, and they handle just fine.
for 8's and maximum performance potential you do want 225/50
for 205/55x16 you would want 7.5, but since Fuchs never made a 7.5, 7 will do fine, 8 is outside the tire manufacturers spec range.
Bill Verburg
Old 04-21-2015, 09:09 AM
Thank you Bill for pointing out the actual true about what tire sizes were designed for what rim width/ You are absolutely correct, and people tend to ignore the fact that the side walls play A big part in not only handling, but safety, and stretching buy putting on a rim to wide or bulging, by using a rim to narrow, while some think it looks cool, is not the proper or size and not designed for most of our styles of driving.
I have both 8s &9s, currently running 7&8X16s with 205/50/16s & 225/50/16s, this choice was based on a couple of things, one being tires available at the time (needed then in a day) the other, we get a lot of rainy weather in FL, and I switch back & forth with daily drivers and the 225s on 8 are less likely to hydroplane if I get caught in the rain.
Old 04-21-2015, 09:11 AM
Das Schnell Ei's Avatar
8" seems like extra wheel for no reason with a 225 on the front no?
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 04-21-2015, 09:59 AM
