evan9eleven's Avatar
Tracked down both 8" and 9" Fuchs, what would you pick?
Looking at a pair of 8 x 16 or 9 x 16 original Fuchs for the rear of my SC. These are in the 911 offsets to give me the look and fit I'm after. I know that the choices for 245 tires to fit the 9's are limited, and that the fit will be almost identical to the 8's on the outside edge. Potential cost differences aside should I focus on the 8's or is there a compelling reason to go with the wider wheels if the price is right?
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 04-07-2015, 08:18 PM
DanielDudley's Avatar
I prefer 7s & 8s. Only you know if you want more tire.
Old 04-08-2015, 01:54 AM
Almost Banned Once
sc_rufctr's Avatar
IMO, Go with the 8s.
- Peter
Old 04-08-2015, 02:17 AM
michael lang's Avatar
either way you go, you have a winning combination. you might as well flip a coin. at one time 9s were really the choice but now 8s/9s, are you really going to see the difference while you're in the car?
Mike
'89 CARRERA
#402
Old 04-08-2015, 03:46 AM
E900's Avatar
I have 9's with 225 tires. Might be worth considering looks-wise. Looks a little tighter than 245 i think. Especially when lowered.
Old 04-08-2015, 04:45 AM
fred cook's Avatar
Wheels...................
I have 7x16s and 8x16s on my SC. I am running 245-45x16 Falken rear tires on the 8x16s with no problems. In the long run, the 9x16s will likely be more valuable than the 8s, so why not "invest" in the future?
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-08-2015, 05:29 AM
Undocumented User
McLaren-TAG's Avatar
Buy them both.
Old 04-08-2015, 05:41 AM
I would also say buy them both. If you don't buy the 8"x16" can you refer me as I am looking for a set.
Old 04-08-2015, 07:46 AM
Senior Member
Jdub's Avatar
Most folks cannot distinguish between the two, so either will give you a great look. I am running 7"/9" and must recommend the Bridgestone Potenza in a 245 configuration - freaking awesome footprint from behind esp. with a lowered car.
BTW, in alignment shop, after suspension rebuild, I was asked what configuration I wanted (Street, Race, etc.) and opted for pure Street. Even with this config., my rear wheels have a slight camber unlike the pics above.
'78 Targa in Minerva Blue
Old 04-08-2015, 08:03 AM
Senior Member
Jdub's Avatar
Oh, and be sure to roll your front fenders before you get the 7", esp with a 225 tire set.
Old 04-08-2015, 08:05 AM
Fastest Hunk of Junk
If you have to pick between the two, 8s all day. Not enough selection in 245+ 16" tires to justify 9s, unless you can put race rubber. Then it's 9s all day.
-Brent
Old 04-08-2015, 09:07 AM
Wer bremst verliert
JohnJL's Avatar
OP, what do you have on the front?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-08-2015, 10:05 AM
I'm running the stock 6x16 and 7x16 fuchs now, looking to move the 7's to the front with 205's, and 225's in the rear. 8's are sounding like the best choice.
2004 Boxster S
Old 04-20-2015, 01:02 PM
Bill Verburg's Avatar
depends on what you want
to maximize performance potential 8 & 9 will be wanted, 7 & 9 is one notch down and 7 & 8 another notch down. That said you want to optimize the rubber and other suspension components to get the most from the car. one potential choke point is the rear tires for 9, you would want 245/45 x16 there are only a few choices for the tire in a high perf street version, fortunately B/S RE11 and Toyo T1R are 2 of them.
nothing wrong w/ 7 & 8 as that was the factory sport suspension option for many years
Bill Verburg
Old 04-20-2015, 02:25 PM
I seem to recall that if you want to run 8'' Fuchs in the front, you need 944 offset wheels.
Old 04-20-2015, 06:40 PM
correct, for 16" Fuchs only the 8x16ET23.3 Fuchs is possible in fron w/ stock front fenders and it's a tough fit, most that use 8" front use aftermarket wheels w/ more appropriate ET.
Bill Verburg
Old 04-21-2015, 05:00 AM
Alex973's Avatar
oh you lucky devil, grab both 8,9 worth a lot more a week after your
purchase, good luck
"IGNITION LEFT OF STEERING"
Alex
Old 04-21-2015, 06:55 AM
Shaun @ Tru6's Avatar
245s fit on 8s perfectly fine.
Tru6 Restoration & Design
Old 04-21-2015, 07:36 AM
8 and 9 inch wheels
I am using 205 55 16s on 8 inch rims and 225 50 16s on 9 inch rims. I personally like the look of a wheel rim that is as wide as the tire, and they handle just fine.
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries!
1974 911 RUF Clone ('85 3.2; '86 915)
1974 914 ('87 3.2L & 915 transaxle)
2005 Boxster (Base car) Guards Red.
Old 04-21-2015, 08:07 AM
redridge's Avatar
thinking of doing 8" and 225s all around... add 5mm spacer in the rear.
Old 04-21-2015, 08:55 AM
