Both these Proven Inventions USED TOGETHER will be installed by A West Coast DIY'er for the first time in his 911
The 911 A/C System will also use a Variable Orifice Valve VOV Instead of a Thermal Expansion Valve TXV Last edited by KelogGes; 04-25-2015 at 06:36 AM.. |
The West Coast 86 Carrera Cabriolet DIY owner is on-board with me to also install as part of his installation besides "Reversing The Gases" Micro-Processor Control of SUPERHEAT & TEMPERATURES
non-whiner
Just for the record that's not slander, it's libel.
As in written, not spoken. Shaken, not stirred.
"Too much is just enough." |
Is that possibly how/why you got MINUS 3-4 PSI low side pressure during your "reverse the gases" test..?? Assuming the system was operable, no blockage to refrigerant flow upstream of the compressor inlet, how much "SuperHeat" would that equate to..? |
Have you considered an Iphone ap via Bluetooth for the top level control./display? Larger customer base if the console "factory look" can be left intact. |
This 911 HIGHLY MODIFIED EVAPORATOR Picture is from The Tan Swan COMPLETE A/C New Technology PROJECT I did over a year ago,
THIS IS NOT THE WEST COAST DIY 1986 SC Carrera Cabriolet 911 Evaporator! However, the Tan Swan had “REVERSING THE GASES” #3 installed and also USED VOV technology instead of a thermal expansion valve Note: the Tan Swan did not have DIGITAL SUPERHEAT or Temperature control; The Analog electrical controller you can see in the picture is for the highly modified evaporator & blower This picture is posted for the WEST COAST DIY 1986 SC Carrera Cabriolet 911 Evaporator OWNER! Note: This picture was taken during The TAN SWAN installation; The Smugglers box cover closes normally in the completed installation by carefully slightly bending the evaporator inlet tube just a little lets cover fit Perfect. (The Larger modified Blower motor however required smugglers box cover to be modified due to the height of the larger/taller blower motor)
Heat wave! South Florida breaks temperature records
TODAY Sunday, April 26, 2015
96 Degrees ambient Fort Lauderdale & Miami 99 Degrees Boca Raton Heat wave! South Florida breaks temperature records | Miami Herald Miami Herald Last edited by KelogGes; 04-26-2015 at 03:35 PM.. |
Yeah, it was 97 with a"feels like" of 101 in Miami, was going to get the 911 out for testing, but couldn't due to family commitments , have to watch until the next heat wave.
The other P car's a/c is great though.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
HUMIDITY TODAY ONLY 45%
Heat Index = 106 F / 41 C @ 90 % Humidity Heat Index = 158 F / 70 C Heat Index Calculation Last edited by KelogGes; 04-26-2015 at 05:25 PM.. |
El Duderino
Just sayin'...
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Banned
Fleabit peanut monkey
The butt skunk will do anything to keep his thread in the top 20.
1981 911SC Targa |
El Duderino
You are so obtuse, it's almost cute. Almost.
Banned
Like this?!?!
State of The Art PFC Technology custom made for early model 911's also using my discovery Reversing The Gases
CAPABLE OF 30's DEGREE A/C VENT TEMPS @ 95 DEGREE'S AMBIENT 5 LBS 5 OZ's Total Weight of my new version of BOTH FRONT & REAR PFC/s Front PFC ONE pound .95 ounces Rear PFC THREE pounds .56 ounces ![]() The Top PFC takes a shoe horn to fit it into the cavity between the front wheels but fits perfectly into the body NOTICE the curve to perfectly fit the the contours of the full width of the deck lid outside air inlet on the bottom PFC so you can completely seal the rear pfc to the deck lid! Last edited by KelogGes; 04-28-2015 at 08:52 AM.. |
Or "B", you are only outing the efficiency of your condensers in providing an adequate supply of liquid refrigerant at 95dF..??? Last edited by wwest; 04-28-2015 at 10:02 AM.. |
222.9 CFM EACH X 4 = TOTAL 891.6 CFM's
Front PFC ![]()
