Any gain from disconnecting the A/C compressor on my '88?
I have an '88 Cabriolet which came equipped with air conditioning. The A/C hasn't worked in years and I don't feel the need to ever use it.
I do have the belt connected still so the compressor is still turning. I'm wondering, if I cut or remove the belt, is there any advantage in power? I suspect there is very little load from a non-functioning compressor but I thought I would ask. |
Remove the belt.
Small gain. Compressor does not spin unless A/C is on engaging clutch, and when full throttle it also disengages.
Ed 1973.5 T |
The compressor should run with very little friction, but if you don't use it then take the belt off and also unplug the wires from the compressor (in case someone turns the switch in the center console). I went the whole nine yards and took the whole A/C system out ('86 Cab). Get's a little hot in the middle of the summer in Virginia, but hey, it's a Cab anyway.
Juergen
'86 Carrera Cabriolet Grand Prix White '09 VW Beetle Convertible ‘24 Audi Q8 etron |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Compressor cutoff
Thanks, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Remove the belt and it will never fail and take out the alternator belt.
Any gain would be a virtually unmeasurable and due to the friction of the belt turning over a free turning pulley. I doubt any dyno on the planet could tell the difference. You can take the compressor off and just plug the hoses to keep them clean. It would be easy to re-install the AC that way. With a Cab I doubt you are going to use it as a track whore so stripping the few pounds of AC stuff is not going to change it much.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I would assume you probably have no freon in there anyway, so the biggest gain would be to remove the compressor itself and reduce the weight of the car by ~40 lbs. Plug the hoses. The other AC components would be too much work to put back on if ever needed so probably not worth removing.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... Last edited by jwakil; 04-20-2015 at 12:43 PM.. |
Total waste of time with no gain whatsoever.
ok now the opposing viewpoint from another 88 cab owner
If it doesn't work then fix it, you are driving a 911 cabriolet-I'm sure you will elevate a woman's temperature at some point and be glad you still have it. |
remove the belt.
at the very most i would just remove the compressor but leave everything else. YOU may not want it but some day you may want to sell it and the next guy may want it. then just put the belt/conpressor back on and give the ole "it only needs a charge" story.
Former Options Trader !!!
This debate always reminds me of a line from the movie Blues Brothers.
After Elwood picks Jake up from prison they go back to Elwood’s place in Chicago. His apartment is right over an area were the EL has three different lines and you can hear the trains constantly. Jake asks Elwood… “How often does the train go by” …. Elwood’s answer is … “so often you won’t even notice it” Will there be any increase in power by removing the compressor belt? ……. “So little you won’t even notice”
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster |
Diss Member
The gain is to remove the compressor completely. That is a big slug of weight in exactly the wrong place.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
It was pretty warm, and the sun was beating through the windshield on her side. The A/C works, but has original hoses, and I have not done the annual recharge yet. She says: "why are you fixing the seats and the seat heater (my next project) instead of fixing the air conditioner?" So I ordered new barrier hoses from our host Saturday night.
07 Boxster 88 Carrera Cabriolet 3.2 (sold) 05 Boxster S (sold) |
its not a race car.
i just took the comp off my 930. the only thing i can notice is it is easier to get to plug #4. (i have too many leaks right now. the rear condensor and the line that runs down the left side of the car). the ac WILL go back in.
