Madsimilius
Do i need new synchroniser rings ? G50/00
Last year i bought a g50/00. I have taken it apart to shorten the bellhousing , and i'm about to put it back together. I'm thinking of buying new bearings and synchroniser rings, but i'm not sure if i need to. Is there any good way to measure/see if the rings and bearings are worn out ?
911sc, 3.1, ported 40mm, cams and titanium retainers, carrera 3,2 intake, ms3x, k27/k29, full exhaust, |
gearhead
You need to install the synchro onto the cone of the gear and measure the gap with a feeler gauge. I would need to double check the spec but iirc minimum gap is .8mm.
Madsimilius
does that mean minimum for what's ok to put back in or that they should be changed at 0.8. Mine were at about one 1 mm . do you know how big the gap is when they are new ?
gearhead
1mm is pretty good. They aren't much more than that new.
Madsimilius
If anyone knows what to look for to see if i need new bearings id be very happy to know
and thank you Matt
Madsimilius
good to know. I can see that the transmission has been opened before since the original gaskets have been replaced some orange sealant. So it might not need any rebuild.
gearhead
G50 bearings are really robust.
Chain fence eating turbo
How much power you are you pushing?
I'm around 650 according to TurboKraft with my combo, and have never had any issues. |
