Madsimilius
Madsimilius's Avatar
Do i need new synchroniser rings ? G50/00
Last year i bought a g50/00. I have taken it apart to shorten the bellhousing , and i'm about to put it back together. I'm thinking of buying new bearings and synchroniser rings, but i'm not sure if i need to. Is there any good way to measure/see if the rings and bearings are worn out ?
911sc, 3.1, ported 40mm, cams and titanium retainers, carrera 3,2 intake, ms3x, k27/k29, full exhaust,
Old 04-24-2015, 07:19 AM
gearhead
You need to install the synchro onto the cone of the gear and measure the gap with a feeler gauge. I would need to double check the spec but iirc minimum gap is .8mm.
Old 04-24-2015, 08:13 AM
Madsimilius
does that mean minimum for what's ok to put back in or that they should be changed at 0.8. Mine were at about one 1 mm . do you know how big the gap is when they are new ?
Old 04-24-2015, 10:49 AM
gearhead
1mm is pretty good. They aren't much more than that new.
Old 04-24-2015, 10:51 AM
Madsimilius
If anyone knows what to look for to see if i need new bearings id be very happy to know and thank you Matt
Old 04-24-2015, 10:53 AM
Madsimilius
good to know. I can see that the transmission has been opened before since the original gaskets have been replaced some orange sealant. So it might not need any rebuild.
Old 04-24-2015, 10:57 AM
gearhead
G50 bearings are really robust.
Old 04-24-2015, 11:13 AM
Chain fence eating turbo
How much power you are you pushing?
I'm around 650 according to TurboKraft with my combo, and have never had any issues.
Old 04-24-2015, 12:39 PM
