Yags (guest)
Guest
Posts: n/a
Hi Guys,
I just had the DME relay changed on my '87 Carerrera BC it wasn't starting. A week later and it's not starting again. Trying to trouble shoot myself but I'm a 0/10 mechanically but easy to teach. It's turning over strong but no boom. How do I check the plugs or take them off? I can look for spark and guess it's a fuel issue or find gas and it's a spark issue? Pls advise. My manual doesn't show detailed pets in engine on a diagram.
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-18-2015, 08:48 AM
http://www.pelicanparts.com/techarticles/mult_ignition_trouble_list/mult_ignition_trouble_list.htm
This should get you through a little bit of the process.
Pay close attention to the section about checking the CD Box, listening for the whine is a quick easy step, and can cause your issue.
Get yourself a fuel pressure gauge, and a spark checker.
- Casey
tharbert's Avatar
Spark checker: Pull the plug wire from the easiest accessible plug. Find/get a spare plug and put on the plug wire. Rest the base of the plug/wire against some metal ground. Have someone crank the motor and look for a nice bright blue spark.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 05-18-2015, 10:45 AM
ROW '78 911 Targa
timmy2's Avatar
Bad new DME relay?
Bell curve failure rate is pretty high on the URO brand. Pay the extra for OEM ...
Old 05-18-2015, 10:56 AM
fetus's Avatar
Do you have a Harbor Freight close by? Pick up a fuel pressure kit and a Noid light kit. You might want to pick up a Volt Ohm Meter too.
I would also pick up a Bentley Book. It has a nice troubleshooting section. Shows how to bypass the DME relay to check the fuel pump as well as tests for ground, voltages and sensors.
75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts.
Old 05-18-2015, 11:21 AM
I find that testing spark is a first step. I keep an inductive spark testor, like this one www.amazon.com/exec/obidos/ASIN/B0002STS3U/awh?tag=viglink20245-20, is my old cars. It will let you know if the plus(s) is/are firing.
Wayne
1980 911 SC
1960 MGA 1600
Old 05-18-2015, 01:05 PM
