dickster's Avatar
need imaginative ideas to split calipers
i want to split some 930 calipers to rebuild them - they are not on the car, as they are replacements for my carrera calipers.
how can i get those damn tight bolts undone to separate them WITHOUT
1. airtools
2. a vice
3. putting on car
4. local wrench
i do have the correct size allen, with an 18 inch extension bar for leverage - but can't hold the caliper.
any bright ideas? i think its impossible
Rich
'86 coupe
"there you are"
Old 11-10-2002, 08:54 AM
Bones's Avatar
don't take the calipers apart unless you absolutely have to.......if you want to simply clean and use a caliper repair kit on the pistons you can do this without splitting the calipers........recieved opinion is that in putting split calipers back together it is very hard to get them to be leak free again
Old 11-10-2002, 09:05 AM
Unregistered
sammyg2's Avatar
You could try using a hammer to hit hte wrench but if they are that tight you will probably just round them off.
I would bit the bullet and take them to a shop. For a few bucks they will use their air tools and get them loosened up in no time without having to drill out rounded off bolts.
Bill Verburg's Avatar
Bite the bullit and have a pro do it. It would be a shame to see them ruined/marred through the use of improper tools.
Bill Verburg
Old 11-10-2002, 09:06 AM
i would try an hand held impact driver after a good soaking. clean the 8mm allen head holes to make sure the bit is bottomed.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 11-10-2002, 09:08 AM
dickster's Avatar
ok, fair point. i just thought i'd take a shot in the dark.............
i must admit i had a go a while back and was worried that i would round off the allen heads. the rears were sent to vci and they split them easily....
btw - bones, the 930 calipers can be split - they're two separate units with their own brake lines. i fell into the same trap as you before i knew...........
Rich
'86 coupe
"there you are"
Old 11-10-2002, 09:12 AM
Senior Member
Doug Zielke's Avatar
Are you $hitting us, Dickster?
You mean to say you don't even have a lousy 'ol bench vice?
Start building a workshop my man, or you'll be forever at the mercy of schlocky mechanics and other assorted felons.
(In the meantime, while that de-lux workshop is a-building, just take your caliper to the UK equivalent of Midas.)
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 11-10-2002, 09:16 AM
dickster's Avatar
LOL
doug,
no i'm not!! i can just about fit the car in the garage, let alone a bench for a vice. however, up until now i have got away with it.
i have only been in the house for 3 years and had loads of other stuff to do. high on the list will be a bench (don't know how!!) and a large vice.
Rich
'86 coupe
"there you are"
Old 11-10-2002, 09:28 AM
Bones's Avatar
cheers Dickster that's nice to know if I upgrade to 930 calipers........
Old 11-10-2002, 09:32 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Old trick from Harley days.....
Get a length of steel (square tube works best)....drill 2 holes in it the same distance apart as the mounting bolts for the caliper.
Now stick a couple of long/strong bolts through the holes sticking up
Place the caliper over these bolts....maybe run a nut or 2 down on them if you feel the need.
Now you have a lever to hold the caliper (on the ground)...no vise needed...
Enjoy !
Bob
Bob Hutson
Old 11-10-2002, 10:36 AM
nick-moss's Avatar
Hi Dickster.
I split some 917 calipers this afternoon, the allen bolts were free enough to loosen them by holding the mountings in a vice without any damage.
Try the Harley method above.
You don't need to worry about causing leaks as the saddles do not have any fluid passing through them..
Nick Moss - RGruppe #318
early911.co.uk
Old 11-10-2002, 11:00 AM
dickster's Avatar
thanks for the tips.
Rich
'86 coupe
"there you are"
Old 11-10-2002, 11:12 AM
Just a tip, I spoke to Doug at VCI and he says the 930 almost never need rebuilt. Don't get hot enough.
Old 11-10-2002, 03:05 PM
Senior Member
Superman's Avatar
The bench vise is a primary tool. As basic as the screwdriver.
Mocha 1978 911SC. "Coco"
Old 11-10-2002, 04:17 PM
dickster's Avatar
Are you $hitting us, Dickster? You mean to say you don't even have a lousy 'ol bench vice? Start building a workshop my man, or you'll be forever at the mercy of schlocky mechanics and other assorted felons.
doug,
i was so ashamed.............
one new bench, with 5 ton vice on the right. ok it needs tidying!!
i even plumbed in the washing machine (pipes under bench).
then i had a few beers
Rich
'86 coupe
"there you are"
Old 11-27-2002, 12:50 AM
dickster's Avatar
another pic.........
i already used the vice when i did the plumbing, so its already paying for itself!!!!
Rich
'86 coupe
"there you are"
Old 11-27-2002, 12:54 AM
AirCooledExcellence's Avatar
Wow, bench building and plumbing, the skills of people on this board never cease to amaze me
Nice Job!
Cheers,
Tim.
PS: Shouldn't you have lagged those pipes??!!
____________
1983 SC Targa
Old 11-27-2002, 01:04 AM
Siena911's Avatar
Another one with a small garage. It does my head in sometimes, at least this way I cannot store junk in my garage
I like the idea of a bench at the back tho, I might look at doing something like that. Nice idea.
Jakes
If you want to run with the big dogs, you can't pee like a puppy!!!
92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!!
81sc / 3.2 litre transplant (Broken BIG Time )
SCWDP deserter - HP junkie wannabe
Old 11-27-2002, 02:28 AM
beepbeep's Avatar
Do not split 930 calipers unless you absolutely have to.
That's what dealer mech said to me. Just put in some new gaskets.
Thank you for your time,
Old 11-27-2002, 02:44 AM
dickster's Avatar
thanks tim, jack of all trades, master of none - thats me!
jakes, i ain't moving from this house unless i find a place with a double garage!!
yeah, its pretty small in there. i made the bench high enough to clear the whale tail which will slide underneath. i have to get the car right in there to make room for a big sports bike that sits in the front!!
the bench is narrow as well - just 18 inches. but its much better having it.
on the subject of splitting the calipers. beep beep, new gaskets?? where??
i want to split the fronts to rebuild them. as far as i know theres no problem splitting them, they're made of two separate units bolted togther, with the fluid running from one to other through an external line (not through the casting).
Rich
'86 coupe
"there you are"
Old 11-27-2002, 04:28 AM
