Brew Master
Adjusted shift coupler and bumping R when downshifting
I know I need further adjustment but I'm not sure which way to turn the coupler to get it to stop bumping R when downshifting out of 5th. I had an incident where the strap that tightens the shift rod to the spline shaft of the coupler got loose and slipped off. Now I can't seem to find the sweet spot. I adjusted according to the PP write up but can't get it to stop bumping R on downshift. Which way do I turn to correct and should I be turning the coupler or should I be moving the shift lever?
For the record, all bushings are new so that gets ruled out as part of the problem. |
If shifting to all the gears is OK, don't rotate the coupler! Rotating the coupler will not affect it, and will likely mess up gear selection. Just adjust the fore and aft of the coupler on the shift rod till it shifts without nicking reverse.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
+1 for fore and aft. That worked for me.
Wayne 1980 911 SC 1960 MGA 1600 |
Rescuer of old cars
uwanna and heimtun are correct. You are dealing with fore & aft, not side to side. This is generally (always?) because the lever isn't moving far enough forward as you move into fifth, and so the reverse lockout cam is not tripping.
I had this problem with a factory short shift kit. The "sweet spot" where I could shift into 2nd, 4th and reverse but still trip the cam was impossibly small. To change this, you will need to move the coupler rearward on the shaft, but probably only a minuscule amount.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
I had the same problem; solved the problem by lengthening the distance between the shift lever and coupler.
My 83 had the reverse bump after a Fairbanks rebuild. I took the trans back, he inspected his work, just off hand asked if I had a short shift in the car. I did, that was the problem.
Bruce |
Brew Master
Arne, I'll have to look at my shifter when it's in 5 and make sure the lock tab is engaged when I'm in 5th gear. Thanks for the tip. Last edited by cabmandone; 06-23-2015 at 04:45 PM.. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Shifter.
Sorry to step in, but I also have a shift rod/coupler issue.
Coupler, and shifter bushings are new. I have all the gears, but the shifter is close to my knee when in second gear. When I rotate the shift rod towards the driver's side it gets better. But then, I have the fifth gear hard to engage issue. Also, with the factory short shift. Any thoughts? Thanks in advance, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 06-25-2015 at 06:51 PM.. |
Brew Master
![]() Seriously though, I'm about 6'1 and had a bit of the same problem so I put a 3" extension on so my shifter isn't as short as I make it out to be. |
In some cases, this 3" lever extension may help: ![]() Sherwood |
Brew Master
As it turns out, I was smarter than I gave myself credit for. While doing some adjustment work today I had a flashlight pointed at my coupler and noticed a line scratched where my shift rod and coupler matched. I had forgotten that the last time I adjusted the coupler, I took an awl and scratched the spline shaft to show where it lines up. For what it's worth, I adjusted the fore and aft several times and it ended up being I needed to slightly rotate the coupler. Now, no bumping R when downshifting.
Thanks for all the help and suggestions. They are always appreciated. |
