IMR-Merlin's Avatar
Red face Anyone have a picture of a 79 fuse block
I have the 84-up Bentley here but nothing for a 79.
Someone really dug deep into my 79's wiring trying to "fix' a no start issue. I have found the original cause (hidden kill switch) but now need to undo all the other problems.
There is all sorts of bad things done to this poor fuse block and I would really appreciate a picture of an unmolseted one to make sure the wires go back in the right spot.
Thanks in advance
Brendon
Old 07-12-2015, 06:20 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuse Block.
Thanks in advance
Brendon
https://www.google.com/search?q=1979+911+PORSCHE+FUSE+BLOCK&rlz=1T4GUEA_enUS570US570&tbm=isch&tbo=u&source=univ&sa=X&ei=1ZeiVdj1OI3VoATKjb_YDQ&ved=0CD8QsAQ&biw=1140&bih=715
Here
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-12-2015, 09:33 AM
IMR-Merlin's Avatar
I am actually looking for a physical picture of the box installed in the car with wire colors going in and out of each fuse location from a US 79 SC so I can try to get this car back together and running correct.
Someone did some real good messing around with the wiring in an attempt to get the car running because they didn't know where the PO hid a failed kill switch...
Old 07-14-2015, 08:04 AM
anthony's Avatar
How can you trust someone's picture? I thought my 90k mile car was relatively unmolested but I'm finding a few inconsistencies in my fuse panel. Some has been in there for some reason.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 07-14-2015, 08:12 AM
IMR-Merlin's Avatar
True but it will get me in the ball park for a few things, then i can sort the rest out.
Beats the guess work while I wait for my mid year Bentley to get here. Mainly on the hot side of the fuses.
Old 07-14-2015, 08:22 AM
76 911 Before restro
Old 07-14-2015, 09:54 AM
BlueWing's Avatar
Might not be a big help but this is from my 79 ROW. I added a 3 fuse block to the far left to fuse the dimmer/directional stalk control for the high/low beams and 2 relay sockets to the far right for the high/low beams (relay for low beam was not in place thus empty socket). The rest appeared original before my additions.
Not sure if any will apply to your USA 79 but maybe get you started.
Terry
79 SC Minerva Blue ROW
Non Sunroof Crank Window Coupe
3.0 SSIs, Backdated Heat
COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires
Old 07-14-2015, 10:29 AM
IMR-Merlin's Avatar
I already printed this picture off from another thread!!! LOL
Terry
Old 07-14-2015, 11:45 AM
OsoMoore's Avatar
My 79 had some modifications by a previous owner. I took extensive notes, took the fuse box apart, and built a new setup with modern ATO fuses. I can link you my notes - maybe it will help.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go!
Old 07-14-2015, 12:52 PM
OsoMoore's Avatar
Sick Of It! Time to update my SC Fusebox
Good luck!
Old 07-14-2015, 12:54 PM
evan9eleven's Avatar
The original panel in my '81 SC before I replaced it with a Fred Cook panel. Not sure the pic helps as its not totally original but close. Number 21 on the far left is missing (power windows) while 19 and 20 are A/C. Good luck!
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 07-14-2015, 01:27 PM
ROW '78 911 Targa
timmy2's Avatar
Just download the '78 schematic from Pelican. It is the same.
http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-14-2015, 01:34 PM
Jonny H's Avatar
Our offering if it suits you. 50+ installs so far.
New company and new products. 'Classic Retrofit' 911 Fuse Panel and CDI+ ignition.
Old 07-14-2015, 01:37 PM
IMR-Merlin's Avatar
Originally Posted by Jonny H View Post
I've seen your work and the other ATO swaps. Nice work and thanks for reaching out but I am trying to not make this a project car. I already have my EFI 930 with a custom harness in it.
I want to get this back to as original as possible for resale.
Brendon
Old 07-14-2015, 02:56 PM
