Humbled by 78 SC again... Where does this stuff go?
Completed a fairly extensive paint job and thought I'd freshen up the engine a bit. Can't find a home for two brackets and three chingaderises. Somewhere around the alternator/fan? Any help greatly appreciated.
El Duderino
The 3 silver things on the left are bracket that attach to the top of the fan shroud. The heater hose that comes out of the right bank of heat exchangers lays on top of them and there are clamps that go around the hose that hold the hose to the bracket.
Pretty sure the top right bracket goes on the back left and holds up part of the CIS stuff. I think it sits in the throttle bellcrank.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
ROW '78 911 Targa
Bottom piece is the support structure for the blower motor. The motor sits in the curved part and is held by a strap.
Top right bolts to back of air box rubber isolator stud and to one of the bellcrank bolts.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 07-14-2015 at 07:52 PM.. |
1 The large black piece on the lower right goes in the engine compartment to hold the heater blower on the drivers side. It bolts to the #2-3 intake manifold.
Mine looks different because i cut the top of the bracket off. ![]() The upper right black piece looks like the CIS airbox to engine bracket. It connects to a bolt near the center of the engine farthest from the bumper to a spot in the cis box through a rubber buffer.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! Last edited by Dr J; 07-14-2015 at 07:52 PM.. |
Pic of upper part.
![]() Near the cold start valve. Again ignore the non-stock components on my metal airbox.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
Thank you, thank you!
