B&B headers 3.2 running hot?
Has anyone after installing B&B headers with heater box noticed engine temps higher than before? I have never had a 911 run above the first white mark under normal driving conditions. Outside temp mid 80's.
Stephen Retrotech: Classic and vintage Porsche cars, accessories and Porsche parts |
Running hot..........
Probably need to check to see if the headers are causing it to run lean. If so, that could cause the higher heat temps.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Brew Master
Jeff at Rothsport did the set up. Check this picture. Looks like a metal return, that would be getting hot just above the headers. Right? Wanting to drive to RennWerks next week. Motronic. Do you think this could be the problem?
abit off center
I put a metal heat shield between the metal feed line and the headers, you can get heat transfer, that pipe gets pretty hot.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
you had the same set up? where did you attach the heat shield? Any insulation or just metal shield? Did it work? What were your temps before and after?
Brew Master
I don't think that line collecting heat is your problem. Are the lines to your front cooler both warm after you drive it for a while?
BTW, I was driving my stock setup today in the mid 80's and mine was running half way between the first and second line. |
I just replaced the oil cooler thermostat thinking that was it. I drove it on a high 90's day and it was headed for the second white mark? So I replaced the thermostat. Didn't have another 100 degree day, but today on in the mid to high 80's above white line. This is the first hot weather I have driven in since the exhaust conversion. That is just too hot.
Member 911 Anonymous
+ check your header gaskets/nuts are tight and verify your AFR. If too lean she will get too hot and could damage your engine.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Brew Master
I'd think if you're running lean you'd feel and hear some difference in the engine. I'd think you'd get a lean pop or something noticeable. Unless something in the motronic was messed (AFM or a chip) I'd find it really hard to believe you're lean. Last edited by cabmandone; 08-02-2015 at 05:20 PM.. |
I would wrap that oil pipe with Aeroquip sleeve, at the very least, to help deflect radiated heat. I would also make certain the front of the oil cooler is not partially obstructed with dirt, bugs and other flotsam.
I had a 930 run considerably hotter after B&Bs. The heater boxes were the same design. There were major gaps in the top sheet metal around the exhaust tubes that pumped hot air directly up against the heads. I ended up making slip in metal heat shields wrapped in heat blanket to get the temps down.
I have had the same exhaust setup for 6 months now. Also have a sw chip and k&n cone. My dd is down so I have been driving the 911 daily to work about 40 miles round trip for the past 2 weeks. The weather has been pretty hot too, 95-100 DegF. The oil temp gauge seems to slowly rise just past the 210 DegF mark after sitting in some afternoon traffic.
I don't see a big difference from when the stock exhaust was installed but I'm still running hot due to aircon not working - ha. I may have to look into that soon. I also switched to Brad Penn oil. I think the engine runs a bit cooler now because of that.
Cheers, Jt -84 911 targa |
B&B headers and engine temps
I noticed my average engine temps when down a little after I installed my B&B headers.
I have a SW chip too, and I feel the engine performs even better now with the headers. I chose to wrap mine before installation. Perhaps that has something to do with it. On 100' days here in N Texas, in stop and go traffic, my temps barely get over the first white line (sorry, dont have a numeric Temp gauge) ![]() ![]()
^^^Nice exhaust set-up.
Off topic, but I think the bricks under your jackstands are oriented incorrectly, causing a higher risk of collapse. The holes should be facing up and down.
Dustin |
I thought I noticed a decrease in engine temps with my B&Bs? especially in cold weather it seemed to take longer to warm up. Motor is totally stock 84 3.2 other than that.
What oil crossover line did you go too? What muffler are you running.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Going to buy a mechanical oil temp with capillary to stick in tank to verify accuracy.
So many opinions its confusing. Just checked front cooler for blockage its fine. Mechanic says engine oil thermostat check next. ![]()
No bricks, period, ever.
