Power to Fuse Block
Sorry for such a basic question but where does the power come into the fuse blocks of a '89 Targa? I'm looking at the wiring diagrams and don't see anything connecting the block to the battery.
Thanks |
If it is like my 1985, then the major power runs are sent to the ignition switch for distribution into different buses depending on the ignition key switch position. See my post here:
understanding the ignition switch Two large gauge red wires from the battery go to connections labeled 30. From the ignition switch, power is distributed base on key position to a couple different locations on the fuse panel. Last edited by SpyderMike; 09-05-2015 at 04:41 PM.. |
German wiring is not like American Wiring.
In American cars, you have two groups of fuses, one always sees power and the other is switched by the ignition switch. in our cars, typically power goes to the switch that controls something, then to the fuse, and then to the controlled device.
Thx guys...
Member 911 Anonymous
What are you trying to do, if we may ask?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Install different fuse block...things are going OK. Pretty hot here and I forgot how much this makes the back of my legs ache bending over the fuse block.
