Wew Wew is offline
SC Mutt
Wew's Avatar
Triangle of death re do
Hi all,
1978 3.0 Rebuild motor bottom up. No leaks anywhere on seams or seals, except, ithe triangle of death.
Dropped the motor and took the following pick...
The oil pressure sender, which I put job weld on the top looks like it is still leaking at the base. I.e. The reducer piece that goes into the block. Anyone else deal with this before and if so how did you solve. For good measure I purchased all new again another switch, the actual reducer piece that goes into the block, oil breather housing gasket and hose and thermostat rubber ring (green). Anyone come across this situation and how does one finally conquer the triangle of death?
I am ready for battle.
Thanks,
Gary
Old 10-06-2015, 08:40 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Make sure breather hose is seated properly and the hose clamp is not sitting on the divet of the breather fitment. I mistakenly placed the clamp there and created a leak.
'85 Carrera Targa
PCA/POC
Old 10-06-2015, 09:16 PM
Wew Wew is offline
SC Mutt
Wew's Avatar
Good one thanks. The stock braided hose barely makes it ti the oil tank without routing throug the cis. Quite cloodgey
Old 10-06-2015, 09:26 PM
On an SC, the braided hose needs to be replaced with proper rubber hose that is pre-formed.
Bruce
Old 10-07-2015, 03:33 AM
non-whiner
mreid's Avatar
You didn't mention it, but did you also purchase a new sealing ring for the sender?
"Too much is just enough."
Old 10-07-2015, 04:01 AM
Wew Wew is offline
SC Mutt
Wew's Avatar
O.K. This could be my BIG problem. I thought the washer that came with it was all I needed.
I am attaching a couple of pics to confirm we are talking about the same thing and B that this is the seal I need if this is correct.
Thanks in advance for weighing in on this.
Old 10-07-2015, 03:25 PM
Wew Wew is offline
SC Mutt
Wew's Avatar
Which is the proper rubber hose for the braided hose replacement. Sorry for asking but I want to be sure cause I prefer not to do another engine drop in the near future if possible. more driving and less wrenching at some point will be good.
Thanks,
Gary
Old 10-07-2015, 03:35 PM
Location: behind the redwood curtain, (humboldt county) california
beware studs pulling from mag cases!
Here is a shot of a sudden and massive, (12 quart ~ 4 seconds), leak from the triangle. Note that the nuts are still on the thermostat studs. Likely, some harried soul over-tightened, (pulled) the studs with unfortunate results.
When in doubt, Helicoil.
regards,
chris
Old 10-07-2015, 04:11 PM
gtc gtc is offline
abides.
gtc's Avatar
I used threebond 1211 on both sides of the breather gasket, as suggested in the complete engine sealant thread. No way in hell is that thing ever leaking now.
Graham
1984 Carrera Targa
Old 10-07-2015, 04:58 PM
I don't understand the second picture for reference.
Here is the hoses
93010739900 before the throttle body on the black boot to the fill tube on the oil tank
93010728900. The air restrictor jams into the hose. This is the reason the engine stumbles removing oil cap.
93020738601. Hose between engine breather at triangle and side of oil tank.
Bruce
Old 10-07-2015, 06:52 PM
Wew Wew is offline
SC Mutt
Wew's Avatar
Hi all,
Thanks for the input and advice.
Bruce. The second picture is in reference to m reid mentioning a seal for the pressure sensor.
Thanks again for the input, feedback, and recommendations.
Gary
Old 10-07-2015, 07:53 PM
DRACO A5OG's Avatar
Oh no, the sealing ring on the new switch is all you need. Proper torque is critical as too much will squeeze the seal out and cause a leak.
If you open it, yes you will need a new seal ring.
'85 Carrera Targa
PCA/POC
Old 10-08-2015, 09:19 AM
DRACO A5OG's Avatar
I suggest clean the area once more and check one more time. Paper towels secured by zip ties will help allot for suspect areas/component/s
'85 Carrera Targa
PCA/POC
Old 10-08-2015, 09:22 AM
Dave Kost's Avatar
Is this sealing ring aluminum? Squeeze it out?
Im confused. Can someone confirm if this is an o ring or aluminum flat washer.
Thanks, ( I am putting my 75 motor back together )
Dave K
Old 10-08-2015, 01:59 PM
DRACO A5OG's Avatar
Aluminum Crush Washer aka seal washer
'85 Carrera Targa
PCA/POC
Old 10-08-2015, 03:33 PM
I bought a new switch and the sealing ring is already installed on the switch.
Old 10-08-2015, 07:55 PM
