jwakil's Avatar
AC Fan always fast, no slow speed. What to replace?
My AC fan on my 81 930 seems to range from fast to superfast, no slow setting. Do I need to replace the blower fan switch (911-613-243-00-M100) or is there some other resistor that controls how fast the fan turns at each setting?
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 11-03-2015, 06:36 AM
The resistor pack has a burned out element. It's located under the passenger floor board.
Old 11-03-2015, 07:18 AM
Originally Posted by tru65ty View Post
very, very important! You can not enter heaven without jesus christ!
John 6:47; john 3:3 (ask jesus christ for the free gift of eternal life)
flagged
Old 11-03-2015, 07:19 AM
AC fan
get a variable fan speed kit from Griffith...800-451-7225...and set your desired speed.
Old 11-03-2015, 07:36 AM
As gomezoneill said, it's the resistor pack under the passenger floorboard....very easy job. This happened to me and the part is pretty easily replaceable. Many people have taken the air con system out of the car so there are alot of these parts floating around
'82 911 SC
Old 11-03-2015, 08:13 AM
jwakil's Avatar
I can't seem to find the part in our host catalog? If anyone has a used working one, let me know.
Old 11-03-2015, 11:27 AM
kuehl's Avatar
The ac evap motor resistor speed pack is located in the plastic trapezoid
air inlet plenum; under the RH side passenger foot board.
Inspection:
My AC burns me up --- Summary of fix
If the resistor circuit tests okay, the issue is the fan speed control switch; which you can test while inspecting the resistor pack
Circuit:
http://www.pelicanparts.com/911/911_parts/Electrical/911_electrical_82SC_AC.jpg
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 11-04-2015, 03:49 AM
