wannabee wannabee
WIL84911's Avatar
Shifter slight move replace engine mounts?
Sport mounts on my 84 are about 4 years old. They've gone through 4 engine removal. I am now noticing slight shifter move (about 1/4 inch) when on off the gas. Is this an indication of mounts going?
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 11-17-2015, 07:38 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Most likely the shifter assembly bushing/s.
'85 Carrera Targa
PCA/POC
Old 11-17-2015, 11:43 AM
End play of the transmission shafts will do that.
206 637 4071
Old 11-17-2015, 11:49 AM
How do you adjust or reduce end play in the transmission shafts? I just rebuilt my transmission I did not see any shims or adjustments associated with end play. What shafts are you referring to?
Old 11-18-2015, 03:11 AM
Mainshaft and pinion shaft, held in position by 4 point ball bearings which are held tight against the differential housing by retaining plates. The plates and bearings both can wear enough to allow some end play in the shafts. Being that the shift forks are in the shift sleeves, which are on the shafts, the movement is noticed in the shifter.
206 637 4071
Old 11-18-2015, 05:10 AM
wannabee wannabee
WIL84911's Avatar
Update: no play this time after getting the car back from the shop. Must have been an adjustment issue as they've had to rr the drivetrain. Fyi tranny was just refreshed and my shifter bushings are pretty recent. Thank you John and Draco.
Old 11-18-2015, 06:58 AM
What exactly did they do?
Old 11-19-2015, 06:29 AM
wannabee wannabee
WIL84911's Avatar
Replace removed tranny replaced synchros dogteeth sliders. I assume when tranny went back in the shifter/coupler is a little off. Then I needed to return the car so this time the adjustment is fine. Theres still a small play but not as huge as before.
Old 11-19-2015, 07:29 AM
