86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
The divine window regulator pivot....
Although shown by our host.
Should there be one for our '86 Targa?
I could not find one listed for our '86 Targa.
Thanks in advance,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-14-2016, 12:12 PM
Senior Advisor
James Brown's Avatar
the pivot was removed later and one of the 4 mounting bosses were used as the pivot point, you can see it in the last picture center top
08 Cayenne Turbo
Old 01-14-2016, 12:34 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yes, Dr Gerry, our 3.2s have one. I too could not find a replacement part so I decided to build one from a solid piece of steel dowel and tack weld in place. Mine split in two and is still hanging on.
'85 Carrera Targa
PCA/POC
Old 01-14-2016, 12:42 PM
DRACO A5OG's Avatar
Really? Hmmm strange, I wonder why I have one, maybe a change from 85-86...???
'85 Carrera Targa
PCA/POC
Old 01-14-2016, 12:43 PM
SCadaddle's Avatar
Feel around inside the bottom of the door, probably the very front of the door to find what is missing.
Old 01-14-2016, 02:03 PM
Spring location.
1986 911 Targa.
Only in L.A.:
Old 01-14-2016, 02:05 PM
gtihop's Avatar
where the arrow is on the left. i used a bolt with the head ground down and double nuts.
Old 01-14-2016, 02:13 PM
Nothing missing.
1986 911 Targa.
Only in L.A.:
Old 01-14-2016, 03:19 PM
would that be for m/y 86?
1986 911 Targa.
Only in L.A.:
Old 01-14-2016, 03:20 PM
Spring goes around the part your missing
Old 01-14-2016, 05:37 PM
gtihop's Avatar
Originally Posted by 86 911 Targa View Post
would that be for pre-m/y 86?
yes for 1983 targa
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 01-14-2016, 05:46 PM
I'm not missing any parts.
1986 911 Targa.
Only in L.A.:
Old 01-14-2016, 06:38 PM
Ova Day
msterling's Avatar
The tab on the spring goes through the slot in the pivot. Both of mine broke off and fell to the bottom of the door. I heard one of them break and fall. I think they are swaged in place. The spring tab rotates about 90 deg and stops at the mounting boss near the top of the picture. With less tension on the helper spring your windows will go up more slowly. Live with slow windows, rig up a replacement pivot pin or replace the whole regulator ($$$).
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 01-14-2016, 07:08 PM
Yes you are, there's another piece that goes through the little rectangular hole.
Old 01-15-2016, 06:23 AM
SCadaddle's Avatar
Take a trip to your local RC hobby shop. Find something like this. It fits on the end of an RC airplane engine so that you can mount a spinner on the prop. Bingo. You've got a new post for the spring.
TowerHobbies.com | Dave Brown X-Long Adapter Nut 1/4-28
Old 01-15-2016, 09:46 AM
sky1jord's Avatar
Me too
I've got precisely the same problem, and found a sheared-off "spring retainer" in the door bottom.
Not a big problem to simulate the retainer with nuts and bolts (or similar), but what's the technique for retensioning the spring?
Old 01-30-2016, 10:02 AM
What is your model/year?
Gerry
1986 911 Targa.
Only in L.A.:
Old 01-30-2016, 02:17 PM
steely's Avatar
The retaining pin is not sold separately - msterling is correct - it is a discrete part that is swaged into the hardware, but has no part number as it is considered part of the regulator. It is made of pot metal and is under-designed for it's job - deforms too easily.
Ironically, the true pivot never seems to fail, but is sold alone.
I replaced mine with some 1/4-20 hw (bolt & modified carriage nut).
sky1jord - I sacrificed a short length of copper tubing (before the price went up) to get some leverage on compressing the spring.
Spring retainer that falls out:
I wound up removing the green angle from my 'stop'
winding the spring
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 01-30-2016, 03:56 PM
sky1jord's Avatar
Thanks to all
Gerry - Red '88 Targa, just like yours but a little younger and a little further south. (I used to live on 17th St. in MB and also in Hermosa, but that was a different life - I was dragged out kicking and screaming)
Steely Dan - Thanks for the picture, I got it. I also have a clone of your "retainer that falls out"
I'm way late in saying it, but this forum is absolutely incredible. I hope over time I can make some contribution(s) that repay at least some of I've learned here.
Old 01-30-2016, 09:45 PM
Diss Member
Quicksilver's Avatar
If you look at the picture provided...
...you can see the circular mark on the right side of the slot/hole where the spring retainer was. As it came undone it was rocking/working for a while.
So yes, there is a missing part. Either it is in the door, it fell out of the door, or it was removed at some point.
There are some posts relating to how various people replaced this if you search for them. There are a couple ways to skin this cat.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-31-2016, 12:33 AM
