The sound of a good downshift is hard to beat. Quickly followed by another, and another. Ooooh. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) Last edited by Alan L; 01-29-2016 at 09:23 PM.. |
Hurley Haywood and Motoman heel and toe session in GT3:
https://www.youtube.com/watch?v=YqYeusE8ksk
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
OK I've dabbled with H&T here and there and have never found a true need for it (I'm strictly a road motorist, not a track driver). As far as I understand the most important element of H&T is to rev match to keep the car's momentum from hiccuping when you release the clutch during a downshift. Here's my technique that ASAIK achieves the same result, what am I not understanding?
1. Brake 2. While continuing to brake engage clutch and shift into lower gear 3. Get off of the brake and hit the accelerator to roughly rev match 4. Then release clutch and accelerate further To me the wasted time/element of H&T is that you 1. Brake 2. Clutch and downshift 3. Blip the throttle to rev match while staying on the brake 4. Release clutch 5. Pivot your foot back to be fully on the accelerator and then hit the gas. Seems like a slower (more steps involved) process than my technique because after the H&T blip rather than fully hitting the gas you then are still partially on the brake and need to pivot your foot to be on the gas. Clearly I'm missing something so help me out.
'76 912E '73.5 911T '72 2002tii '88 M3 '17 Mini S Last edited by fastricky; 11-27-2022 at 07:44 AM.. |
Tom and I made this video to help with the understanding of the benefits for implementing the heal and toe double clutch process
https://www.youtube.com/watch?v=0TYD4aOvN80 Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains Last edited by icarp; 11-27-2022 at 04:22 PM.. |
Racer
Sigh....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Reiver
Before synchro box's existed one had to match revs to shift gears efficiently...also. On the earliest cars and even up into the 40's many vehicles came with the accelerator in the middle and the brake right/clutch left. GP driver from the 1950's, Mike Hawthorn, always asked to have his rides set up like that
That is where the term originated as it was very easy to step on the brake with the ball of your foot to the right of the accelerator and touch the accelerator with your heel. We have simply learned to do the same with a bit of ankle gymnastics with the 'modern' layout. Heel/Toe work keeps your car balanced when downshifting thru corners.... not moving the point of balance forward violently as a normal downshift would. Like riding a bike, when you get it you get it.
De Oppresso Liber Strength and Honor 5th Legion |
It's a 914 ...
H&T and double clutching / double de-clutching are related of course, but not the same thing.
Rev matching without double clutching does achieve the benefit of reducing momentary locking of the rear wheels upon selecting the lower gear. Not as much of an issue on the street, but on track it can happen frequently under threshold braking. Helps reduce shock to the drivetrain a bit too. Properly executed double clutching also gets the trans input shaft spinning at more equal speed to the output shaft to ease the engagement of the gear hub and dog/synchro gear. While not necessary, it does further ease the shock and wear on trans parts compared to rev matching, and certainly compared to doing neither. |
'76 912E '73.5 911T '72 2002tii '88 M3 '17 Mini S |
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
I've use the 'heel/toe' technique for ever. Also I've never had to replace a clutch. I heel/toe and sometimes double clutch to keep the clutch and engine speed nearly the same. I have replaced a clutch but only if I had the engine out for another reason.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
Racer
The only good reason to doubt-clutch with a 915 is if you want to make the synchros last longer. Or, if you think it is cool. You certainly don't need to do it. There is no performance advantage in doing it. There is a great reason to do rev matching on downshifts which is to prevent a sudden increase in engine braking.
Until one day I was decelerating on the (curved) approach to a roundabout on a semi-greasy country road where the entrance with priority was completely obscured until you were basically almost on the white line and could see down it. Without any conscious choice, heel'n'toed the shift keeping the weight distribution & braking constant while selecting an appropriate gear for the decision point. And I've used it in the 911 ever since. If all you use it for is to keep the weight bias the same so the car isn't unsettled by you coming off/reapplying the brakes while downshifting - good enough reason right there, in my book. Many seem unhappy with the 911 pedals and the way the accelerator tends to be lower than the brake engagement point. I find hanging the ball of the foot off the brake pedal, turning the foot sideways and rocking the foot to blip with the heel works great. Never felt the need to modify or adjust the pedals - as they seem about perfect to me. I abandoned attempts to left-foot brake long ago though; muscle memory seems to want to drive the left foot down as though it's on the clutch; takes a lot of practice to get past that, it seems...
'77 S with '78 930 power and a few other things. |
Racer
Also, gears are in a constant mesh.....they never crash into each other unless something breaks.
Cheap, easy, quick fix for the pedal relationship when using the stock pedals. VW Beetle gas pedal rubber slipped over a piece of wood paneling glued to a piece of plywood and bolted to the stock pedal.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
If we're doing videos, this just shows you're not really a boss unless you can do it in Gucci loafers.
https://www.youtube.com/watch?v=kzLjZWrpzmQ |
^^^I was about to post that video too, truly an art form with the feet.
CURRENT: 2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black 1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue 2024 Macan White, Beige / 2010 Cayenne White, Black PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey |
It's actually the way he feathers the gas that's most interesting to me.
Heel toe is more faster on track, and will keep the car more balanced as there is less time when the car is not being balanced via brake/throttle. You downshift while still braking. |
Thread Tools | |
Rate This Thread | |
