Original Owner
2. The Fabspeed Stainless Steel 930 dual 4.5" outlet muffler is right side exhaust, left side wastegate. They provide both sides.
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
yes you will have to compensate for the additional air into the mix
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Unregistered
It depends on the boost levels.
CIS measures the mass of the air, not just the volume so it will add more fuel as the turbo adds more air. That happens without any tinkering or modifications. Now, when the boost levels get high enough to overcome the stock system, or when boost levles get high enough that there is a danger of pinging due to high combustion temperatures, additional fuel is needed to compensate. That level is normally regarded as 5 to 6 psi. Anything above that will probably require some additional fuel, anything below that is probably just fine in stock configuration. I ran mine at 6 psi with no modifications to the CIS at all. When i went to 7 psi I installed a hobbs switch to ground the Lambda brain under boost which fooled it into going richer. If I were to go higher in boost I would install a 7th injector. YMMV |
Thanks Gerald,
That's what I thought based on info gathered here-much of it from you ![]() This is a process for me. I could have just bought a 930, or a blown stang to get a fast car, but as Thad said earlier, this is something unique-different, my own. I'm starting with a simple, low boost, bolt on bae kit I'm hoping to get my car's anemic 160ish hp closer to 250. However, while that's in the car, I'll be researching and building a 3.0/3.3, higher boost, intercooled EFI motor. My goal-350-375 HP. It will be a shallow learning curve, no doubt, but I'll enoy every minute of it! Thanks again to everyone for the help and advice. ![]() Last edited by SLO-BOB; 01-03-2006 at 03:48 PM.. |
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
Finally made it over to Thad's. Just want to pass along to those on the turbo fence that it is SOOOOOOOOOO worth it! I was blown away by the power Thad's car has. It just pulls like a freight train up to whatever speed you dare go.
It was also cool to get a first hand look at a quality, coherent turbo installation. Top notch. Thanks Thad for the field trip! ![]() |
Just rec'd my turbo parts which resembles the BAE setup but has aluminum bonnets and small intercooler. Will start install with SSI's after smog time in April.
Could somebody email the pdf manual to me at vcmarine@sbcglobal.net. It would be much appreciated. Thanks Vince |
Unregistered
Vince, I have it at home and will send you a copy later tonight unless someone beats me to it.
As I posted in another thread, I just got my new LM-1 wideband O2 sensor/air fuel ratio meter. I plan to have a lot of fun with it. I also have an idea to hook up an air temperature sender and have the LM-1 record that data to see how hot my intake gets under boost. Anyone have any ideas or BTDT that might save me from having to re-invent the wheel? |
Vince, Manual sent.
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
jcc911
thanks vince |
Original Owner
![]() Quote:
T. please explain in greater detail why the ssi's rob power.
thanks
Original Owner
Its all about speed and flow direction.
The collector is right under the turbo flange and the alternating combustion events from each side are fighting/opposing each other to make a 90 degree turn into the turbine. No place for a wastegate either without one side or the other completely having to overshoot the turbo or a very expensive three way joint. No valve overlap right...talk about back pressure....bad bad bad. The 20 HP you gained NA you just lost and more with a turbo. Unless its a twin. This was a poormans conversion for the early style exhausts on 2.7s who wanted BAE turbo kits but did not want or could not afford to UPDATE to the SC style headers/heat exchangers that use the forward crossover and the collector merges the exhaust (TRAVELING IN THE SAME DIRECTION) infront of where the cat used to be. Nice run to the turbo for speed and a good place for the wastegate. Just look at factory Porsche 930 header/exchangers and see how they manage the exhaust flow to maximize speed to the turbo. Now Dansk and maybe another has a 930 (header only) setup that collects at the turbo...but its 38 or 40 mm primaries and has a three way collector at the flange to the turbo for wastegate, and left and right sides. If you already have the SSI and exhaust backdate investment in your car I would still rip it out and sell them and get some nice jet hot coated stainless steel regular exchangers and fabricate an extension to mount my turbo off the end of a cat bypass pipe. If you haven't already invested in SSIs .......then don't if you're doing a turbo.......
Original Owner
Collection and flow direction like this ....is what you want.
![]() Not like this..... ![]() And the muffler(?) is just as bad doing a 180 wrap around... my apologies to who ever this set belongs too.
I disagree with the fact that the only way to do it right is use the single inlet flange style 3.0 exhaust. If there are diverters installed in the y crossover pipe then you can seperate the to impulse sides(seperate banks) with no issues. the wastegate can be easily seperated in the fabrication it would only be in the crossover. The advantage to the ssis is that the ID of the pieces are 2 each times 2 and the inside diameter of the sc stuff is 2.5 . what I am saying is that I think the ssis can be made to be better in the long run with a new cross over. No offense Thad I know you have a very extensive back ground in this but that is my theory
Original Owner
I like this one....
![]() or this one.... ![]() These are good designs... But the one in the BAE kit for 2.7s posted up above was not efficient and robbed off a lot of usable power. It was just a pipe with a flange. You would not want to spend a bunch of coin on SSIs then bolt that thing on.
Thad,
Thanks for the info. Still have the stock HE's w/Fabspeed installed. My crossover and muffler setup looks exactly like the pictures. So I'd need an elbow fabbed between the bypass and T04B turbo. I was hoping to modify my GHL 1in1out to keep stock look. I'm willing to sacrifice a few HP. What do you think? Vince |
Yes right on thad thats what I am talking about and will be fabbing up for the folks that want them
But isn't the on pic (pjv's) the same thing just on a smaller scale. Underneath the flange, the pipe is diverted up to the TC from each H/E?
