Fuchs Lug Nuts
Getting ready to replace Turbo Twist wheels on my 911sc with Fuchs my son just refinished for me. Would appreciate help on using the correct lug nuts. Current lug nuts on turbo twist wheels are very light-weight black closed-end lug nuts. Will they work or do I need to buy different lug nuts for the Fuchs? One more piece of info -- I'm told my Fuchs are turbo wheels as identified by the area where the lug nuts seat (counter sunk). Does THIS fact dictate different lug nuts?
This is what my '86 came with
1986 Bosch Icon Wipers coupe. |
a.k.a. G-man
Your Fuchs should have 9x16 stamped on the inside.
This would mean they are "turbo" fuchs. They do not need different lug nuts than "regular" Fuchs.
Сидеть, ложь, Переворачиваться |
The black closed end lugs are factory aluminum lug nuts. They will have a ball seat as opposed to conical that
Most other makers use. They will work with your fuchs.
1985 Iris Blue M491 911 Coupe |
As a side note. When I was is Porsche training back in the 80's..a classmate stated the lug nuts on a 911 were aluminum. They were quickly corrected by the instructor and we were told the OEM Porsche 911 lug nuts are made from titanium. Aftermarket lug nuts were aluminum alloy. OEM 911 lug nuts were to be buttered up with anti-seize on the threads and torqued correctly.
Don't know the OEM lug nuts for a fact are titanium..just what I was told back in the day. Last edited by db_cooper; 03-25-2016 at 03:32 AM.. |
All oe Fuchs come w/ 14mm, ball seat, closed face, Aluminum lug nuts.
These come in black oe, there are also aftermarket aluminum versions in black, polished and chrome There are also aftermarket steel open face mostly used on track cars and there are also aftermarket Titanium, both open and closed face.
Thanks folks....love the forum......great info as usual. Appears lug nuts I'm currently using on turbo twists will work fine with the Fuchs. Thanks again.
RETIRED
Read the threads on broken alloy nuts, you will switch to open faced steel, ricky tick!
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Information Junky
meh, there is no epidemic of Al lugs breaking. No doubt there have been aftermarket lugs made from wrong alloy, but factory Al alloy lugs perform quite well. --and there are a LOT of those in service.
Oh, and you can certainly over torque any fastener to failure. The biggest loads, on the fastener, come from torqueing them on.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee. ![]() |
Registered?
Or you could go with these Titanium gems custom made by Mr. Jim Tidwell in San Diego (jtidwell@speakeasy.net). He makes other custom factory option parts as well.
Brian R Gruppe #757 70T Ex-Waterlogged Rust Bucket http://forums.pelicanparts.com/porsche-911-technical-forum/519605-waterlogged-rust-bucket.html |
Registered?
His recommended lubrication...
Senior Member
You are going to love how this car looks when you get those on!
I use a battery male terminal cleaner inside the lugs to clean the threads, brass brush on the stud threads, and a good jet of air. Check no burrs on the round lug section and a nice smooth surface to mate/twist on. Secret of any good torque is twice, in criss-cross. Get the wheel set square on first torque then hike it to the final spec.
'78 Targa in Minerva Blue |
![]() The biggest issue w/ aluminum is that it is soft, no matter how careful you are the shoulders get munged, Al. closed end, these were new 2 years ago ![]() steel is heaviest and rusts unless painted steel open ended ![]() Ti open ended are lighter than aluminum close ended but are a bit pricey Ti. open ended ![]()
Air Cooled
Love my Rennline steels on long studs:
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Racer
I am a racer and I would never waste money on titanium lug nuts......
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
your opinion here is as valued as much as most of your others
Racer
Okay, Bill. None of the racers I know use titanium lug bolts or lug nuts. Steel is MUCH cheaper and is a better choice in most cases. Why? Just as strong and with less galling and less likelihood of galvanic corrosion. It's just not worth the weight savings.
Thread Tools | |
Rate This Thread | |
