TX911SC's Avatar
Fuchs Lug Nuts
Getting ready to replace Turbo Twist wheels on my 911sc with Fuchs my son just refinished for me. Would appreciate help on using the correct lug nuts. Current lug nuts on turbo twist wheels are very light-weight black closed-end lug nuts. Will they work or do I need to buy different lug nuts for the Fuchs? One more piece of info -- I'm told my Fuchs are turbo wheels as identified by the area where the lug nuts seat (counter sunk). Does THIS fact dictate different lug nuts?
Old 03-24-2016, 06:56 PM
sugarwood's Avatar
This is what my '86 came with
1986 Bosch Icon Wipers coupe.
Old 03-24-2016, 08:18 PM
a.k.a. G-man
Geronimo '74's Avatar
Your Fuchs should have 9x16 stamped on the inside.
This would mean they are "turbo" fuchs.
They do not need different lug nuts than "regular" Fuchs.
Old 03-25-2016, 02:14 AM
oh snap's Avatar
The black closed end lugs are factory aluminum lug nuts. They will have a ball seat as opposed to conical that
Most other makers use. They will work with your fuchs.
1985 Iris Blue M491 911 Coupe
Old 03-25-2016, 02:42 AM
Yep, these are the nuts on mine
Old 03-25-2016, 02:56 AM
db_cooper's Avatar
As a side note. When I was is Porsche training back in the 80's..a classmate stated the lug nuts on a 911 were aluminum. They were quickly corrected by the instructor and we were told the OEM Porsche 911 lug nuts are made from titanium. Aftermarket lug nuts were aluminum alloy. OEM 911 lug nuts were to be buttered up with anti-seize on the threads and torqued correctly.
Don't know the OEM lug nuts for a fact are titanium..just what I was told back in the day.
Old 03-25-2016, 03:29 AM
I think they are NOT titanium. Aluminum or aluminum alloy. BUT ....I could be wrong. What they are is nice and light and durable.
Old 03-25-2016, 03:40 AM
Bill Verburg's Avatar
All oe Fuchs come w/ 14mm, ball seat, closed face, Aluminum lug nuts.
These come in black oe, there are also aftermarket aluminum versions in black, polished and chrome
There are also aftermarket steel open face mostly used on track cars
and there are also aftermarket Titanium, both open and closed face.
Bill Verburg
Old 03-25-2016, 05:16 AM
TX911SC's Avatar
Thanks folks....love the forum......great info as usual. Appears lug nuts I'm currently using on turbo twists will work fine with the Fuchs. Thanks again.
Old 03-25-2016, 07:35 AM
RETIRED
Joe Bob's Avatar
Read the threads on broken alloy nuts, you will switch to open faced steel, ricky tick!
2012 ML350 3.0 Turbo Diesel
Old 03-25-2016, 08:02 AM
Information Junky
island911's Avatar
meh, there is no epidemic of Al lugs breaking. No doubt there have been aftermarket lugs made from wrong alloy, but factory Al alloy lugs perform quite well. --and there are a LOT of those in service.
Oh, and you can certainly over torque any fastener to failure. The biggest loads, on the fastener, come from torqueing them on.
Old 03-26-2016, 08:43 AM
Registered?
blee's Avatar
Or you could go with these Titanium gems custom made by Mr. Jim Tidwell in San Diego (jtidwell@speakeasy.net). He makes other custom factory option parts as well.
Brian
R Gruppe #757
70T Ex-Waterlogged Rust Bucket
http://forums.pelicanparts.com/porsche-911-technical-forum/519605-waterlogged-rust-bucket.html
Old 03-26-2016, 09:08 AM
Registered?
blee's Avatar
His recommended lubrication...
Brian
R Gruppe #757
Old 03-26-2016, 09:41 AM
Senior Member
Jdub's Avatar
You are going to love how this car looks when you get those on!
I use a battery male terminal cleaner inside the lugs to clean the threads, brass brush on the stud threads, and a good jet of air. Check no burrs on the round lug section and a nice smooth surface to mate/twist on.
Secret of any good torque is twice, in criss-cross. Get the wheel set square on first torque then hike it to the final spec.
'78 Targa in Minerva Blue
Old 03-26-2016, 10:07 AM
The biggest issue w/ aluminum is that it is soft, no matter how careful you are the shoulders get munged, Al. closed end, these were new 2 years ago
steel is heaviest and rusts unless painted
steel open ended
Ti open ended are lighter than aluminum close ended but are a bit pricey
Ti. open ended
Bill Verburg
Old 03-28-2016, 07:44 AM
Air Cooled
Craig_D's Avatar
Love my Rennline steels on long studs:
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-28-2016, 09:00 AM
Old 03-28-2016, 09:58 AM
Racer
winders's Avatar
I am a racer and I would never waste money on titanium lug nuts......
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 03-28-2016, 10:31 AM
We don't need your resume
your opinion here is as valued as much as most of your others
Bill Verburg
Old 03-28-2016, 11:34 AM
Racer
winders's Avatar
Okay, Bill. None of the racers I know use titanium lug bolts or lug nuts. Steel is MUCH cheaper and is a better choice in most cases. Why? Just as strong and with less galling and less likelihood of galvanic corrosion. It's just not worth the weight savings.
Scott Winders
PCA GT3 #3
Old 03-28-2016, 11:53 AM
