Follow me
seymore's Avatar
How do I tell which calipers I have?
Hi there,
The title says it all. I have an 82 SC that needs pad and rotors. Ive never done brakes on my 911 and apparently there are A and M calipers? How I can I tell what I have? I did a search but didn't fine what I was looking for. Thanks for your help.
1982 911SC
Old 04-04-2016, 06:18 PM
Max Sluiter
Flieger's Avatar
Should be M's but post a picture to be sure.
Old 04-04-2016, 06:59 PM
Follow me
seymore's Avatar
Thanks Flieger. Im not near the car right now. I'll post one tomorrow.
1982 911SC
Old 04-04-2016, 07:08 PM
Follow me
seymore's Avatar
Here are a few pics of the front and rear. Thanks for the help Pelicans!
1982 911SC
Old 04-05-2016, 11:05 AM
djpateman's Avatar
Photos of the fluid inlet would be more telling. However I suspect that you have A on the front and M on the rear.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 04-05-2016, 12:24 PM
wolds's Avatar
Originally Posted by seymore View Post
Hi there,
Get with Eric at PMB. He's the pro
Old 04-05-2016, 01:34 PM
Bill Verburg's Avatar
A front
M rear
Bill Verburg
Old 04-05-2016, 01:36 PM
pete3799's Avatar
Or Bill
Pete
79 911SC RoW
Old 04-05-2016, 02:04 PM
Stock SC's had "A" calipers in the front and "M" calipers in the rear.
"A" calipers can be identified by the spacing between the mounting bolts - should be 3.5"
"M" calipers can be identified by the spacing between the mounting bolts - should be 3"
Carrera's had A & M calipers too but had a larger spacer between the caliper halves to accommodate a wider rotor. Those are referred to as "Wide A" and "Wide M".
Old 04-05-2016, 02:49 PM
Follow me
seymore's Avatar
Thanks for the help gentlemen.
1982 911SC
Old 04-05-2016, 04:38 PM
