Is there a fuse guide posted somewhere?
I'm having an issue with my window switch fuses popping over and over. Obviously there's a short.
My fuses look as old as the car. Figure might as well replace them and put a big set of spares in the car. Is there a guide posted somewhere so I can confirm the correct fuse sizes are currently in the car? Follow up question, where do you get these "suppository style" fuses? I'm guessing the local parts store would not carry them.
1979 911SC Euro Tub/1982 Euro 3 Liter PCA E Class Race Car 1985 911 Carrera Coupe-Grand Prix White/Red |
non-whiner
Pelican carries them. The guide is on the fuse cover.
"Too much is just enough." |
83 SC
Fuse diagram
This help? Tim
Tim |
1987 928 S4 - Black 2014 C4s 991 - Agate Grey 2014 Cayenne - Mahogany metallic |
Bentley Maintenance manual.........
If you have a Bentley Maintenance Manual, look at the chart or table for your specific car model. Look at the appendix for 'fuse'. Or simply use the previous suggestions.
Tony |
Lots of good discussion here, and various formats of fuse diagrams, if you scan the whole thread:
Made a fuse box label for my 88
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
Make sure your fuses have a ceramic center not plastic.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Also be aware that cars of our age may have had modifications to their fuse layout. My own '79 had a few fuses moved around.
So while it is fine to use the official guides to find the right amperage, don't assume the positions are going to be correct.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
Certified User
There are links to PDF and Visio versions of my fuse box labels in this post.
Feel free to download and modify to suit your car (if you have MS Visio).
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
Ahhhhhhhh
I bought a grip of fuses cheap.....they're plastic. Where can I get ceramic ones? Sorry for the Hijack....Scott
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
Where can I find a fuse guide like the one TKmoore posted for his 88? I have an 85 and would like something model specific if I can find one.
The embossed diagram on the inside of the plastic fuse panel is almost impossible for me to read.
