Newbie MK Muffler Install - How'd I do?
Have you done a compression test on that engine? You may want to do one.
The muffler install looks fine but if that's a stock motor with stock cam somethings sounds off.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
New-ish 911SC Targa Owner
sounds like mine with lots and lots of vacuum leaks including a cracked airbox.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
It sound like that on first start but not during driving. Less "bubbly". It runs strong. You guys are freaking me out. Could the install cause damage? It was an easy straight swap.
Is this a 3.0L SC? I'm sure others will chime in.
Registered Minimalist
+1 lean / miss Sounds like a dragster motor. Check all your plug connections first.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
After I drive it, it idles normal. Just at startup. Will post another video soon
Just have your air fuel mixture checked, but if after it warms up if it goes away I suspect lean at cold start. Common problem in the SC cars is cold start and the warm up regulator.
here it is after short drive. https://youtu.be/ih64NFCgrzM
Yeah sounds much better. Any butt dyno improvement? Really interested in getting the same muffler.
