86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuse panel connections.
The black wire goes to pin # 86 of the
evaporator relay.
G.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-25-2016, 09:00 AM
Originally Posted by 86 911 Targa View Post
As I understand your issue, there is 12v on the evaporator relay pin #30
until you plug the relay into the socket. Right?
Let's start from there.
Gerry
Correct
Old 05-25-2016, 09:03 AM
evaporator relay.
G.
thankyou . I'll check those too.
I love this forum.
Old 05-25-2016, 09:05 AM
Please take the time to make a final post with what the problem really was, and how you fixed it. It is always good to see a solution to a problem.
Old 05-25-2016, 09:13 AM
kuehl's Avatar
Andy,
Assuming you have an 88 to 89 the wire colors at the primary AC relay in the smugglers box will be
Red to relay from AC fuse #2
Red/White from relay to AC evap blwr switch
Black to ign switch
Yellow to the starter circuit
So if you wanted to bypass the AC relay you'd jumper Red to Red/White
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 05-25-2016, 02:22 PM
After all that, I aquired some new fuses today and low and behold after replacing fuse 2, everything works, blower, seats, perfect. Thank-you so much for all the clear trouble shooting. I wish i could have got the fuses yesterday, would have saved you all some time.
I've given myself another problem along the way though. I've broken one of the little springs in one of my electric seat switches. So I'm going to have to find an old switch to butcher.
Thanks again.
Old 05-25-2016, 06:39 PM
kuehl's Avatar
Yawn
Kuehl
Old 05-25-2016, 06:59 PM
Thanks again.
Well done Andy-well done!!!!
I think I mentioned fuse #2 early in the game.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 05-25-2016, 07:27 PM
You did. It was one of the simplest first things suggested.
Thanks again.
Old 05-25-2016, 07:30 PM
