tire pressure
I just bought new Dunlops for my '84 911 carrera turbo look. The tires side wall reads 51psi max .Do I set them all to 51psi or go by the vehicle manufacture sticker in the engine bay which recommends 29psi front and 36psi rear?
RETIRED
29/36.........do donuts in a parking lot, use an IR gun and measure temps, inside, mid and outside. Adjust as needed.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I find something like 33-34 front and 34-35 rear hot to work pretty well for me. a few rules of thumb to reduce under steer raise the front pressures and/or lower the rears to increase comfort lower front and rear if you want to get more into it get a tire pyrometer center hotter than edges - too much pressure edges hotter than center - too little pressure inner edge hotter than outer - too much neg camber outer hotter than inner - too little neg camber tire temp too high in general - pressure too low, tire too narrow, springs/sways too soft at that axle fronts hotter than rear - under steer rear hotter than front - over steer
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Tire pressure.
I pump them up to 44R/35F hot, park the car overnight, then bleed them down. Nice equal tread depth all around. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
My SC liked 32 front, 35 rear.
Also, my condolences on the loss of the officers at the courthouse.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Member 911 Anonymous
OEM 15" fuchs calls for 29/36
However on a recent alignment at West End Alignment, Darin recommends a 4 lbs difference front to rear, so he made it 31/35, note, I have 17"s
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Tire pressure threads are so nice and polite...a nice reprieve from the rancor found in the AC threads
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
![]() Sorry, it was just sitting there waiting.....
