Your Greatest DIY Triumph?
Of all the restoration projects you’ve taken on, which single repair or upgrade on your 911 are you most proud of? If you have any pics, please show us!
*Also, feel free to share your DIY triumph on our Facebook page as well by visiting: https://www.facebook.com/pelicanparts |
I had very little experience with Porsches when I decided to rebuild my 3.0. Put it together with a lot of help from folks on this forum and better than a year later it still purrs like a kitten and doesn't leak a drop of oil.
http://forums.pelicanparts.com/uploads24/image1428712683.jpg http://forums.pelicanparts.com/uploads24/image1428712795.jpg Check out the rebuild by searching rookie 3.0 rebuild
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 Last edited by Amstaff; 06-13-2016 at 06:15 PM.. |
Hmmm... maybe my interior RS style carpets. A lot of trimming and sewing of the edge binding. A lot of time and love was put into that cramped little car. I find a new interior is one of the more satisfying DIY projects you can do as the results are there every time you get in. Still not technically done...
![]() ![]() ![]() ![]() ![]() ![]() ![]() A nice balance of ultra lightness and volume. Kind of a in-between OEM quiet and race car. No harshness, and very sporty yet classy looking. I now have the perfect interior IMHO. (a pro did the seats, but I helped guide the design) ![]()
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 06-17-2016 at 09:11 PM.. |
911 carrera 3.2 (1985)
E-85 sippin drunk
Having help from a good friend (DonE on here) rebuild and highly modify my 3.3L turbo into a 3.6L monster.....
13 year 930 project almost complete!!!!!
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
A Triumph Triumph.....?
Does my Triumph Speed Triple project count as a DIY Triumph.....?
My Triumph Speed Triple project update
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
83 911 Production Cab #10
During the winter break, started on the second try (after I mate the DFU connector...). I never done any mechanical stuff before I got car.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Fixing a nagging engine oil leak.
I pulled the engine and tightened the rocker shaft end bolts to the preferred higher torque value. I couldn't get my torque wrench into the tight space, but a buddy of mine who is an ace vintage motorcycle mechanic told me to file a notch in the handle of my standard wrench handle that was 12 inches from the socket. Then apply force to the handle by pulling downward with a fish-weighing scale, with the hook in the notch, to the appropriate "pounds." Worked like a charm and the engine hasn't leaked since! I did all this, including pulling and re-installing the engine by myself!
Steve B. 1972 911t 1999 328is |
Did an engine swap (with while-you're-in-there work) in my DD years ago. Not complicated - a lot of work, but essentially simple - but it was very satisfying.
'80 SC Targa Avondale, Chicago, IL |
regards, al
Cheers JJ
Autodidactic user
Rebuilt the engine and suspension on my 1973 911E:
Some details. Engine: ![]() Polished fan: ![]() Front suspension: ![]() Trailing arms:
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
winter
Rebuilt my brakes. I'd always been freaked out about working on brakes because the stakes are rather high if they fail.
But it was an easy process and not too bad. Of course, like most posting in this thread, I owe a ton to the members here for the encouragement, guideance and advice and to our host for the technical articles and ample supply of the correct parts at fair prices. Happy wrenching, all! |
Diss Member
Everything related to the Porsche has been rather straight forward because it is a very straight forward car. (Some things might be a pain but they are a straight forward pain!)
Biggest DIY accomplishment was the first engine I built when I was very young. A 215 cid Olds aluminum V8. Pretty much nothing was stock in it. Custom JE pistons, custom cam, hand modified and welded intake, self modified Holley carb, early small block chevy rods shaved .100", FWD Buick V6 water pump, oddball high volume oil pump, Volvo yalve train, Buick 300 aluminum heads, custom oil pan, custom oil pickup, and on and on... (That engine is still in the garage.) Didn't have any guidance on it except for lots of studying any book I could get my hands on. I replaced the 327 in my car with it and the weight reduction made the car AWESOME. 2050 pounds and it out accelerated and cornered most anything you see on the road including the Porsche. (Porsche brakes still KILL!!!) As far as a Porsche DIY episode... That would have to be the "Rubber Explosion™" incident where I went through the engine because of rough running and in the process of replacing cracked intake gaskets I also discovered the intake insulators, the fuel lines, and pretty much every vacuum line was toast. On top of that the DME needed to be resoldered because of a few bad connections. Once it was done it ran like new. Pretty straight forward but pretty irritating.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Rebuilt 1st and 2nd gear in my SC's transmission. Couldn't have done it without help from John Walker, Matt Monson, and many others here on the board.
Can't Shift Into First ![]()
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Painted my front spoiler. First ever try and turned out quite well, until a rock hit it...
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold )
Perpetual Reassembler
So far, and Porsche related?
Removing the aftermarket alarm that was disabling my car and getting it to run again. ![]() ![]() Currently trying to beat that by rebuilding my engine.
Jose - 1983 911SC Coupe Instagram: @joe_engineer 911 D I Y Blog: joe-engineer d o t c o m D I Y Vids: https://www.youtube.com/joeengineer |
It's a trap...
Engine rebuild first, trans refresh second, odo gear...bearings...cv joints...tie rod ends...steering gear box bearings...pedal cluster...struts...clutch cable...etc...blah blah blah
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). |
