Need Help Identifying loose Wire in Front Fuse Box
I installed my classic retrofit fuse panel last night and I was very careful (I thought) to transfer wires one-at-a-time and when I was all done, a little wire showed up - Dang!
I checked all my before photos and I can't see this wire anywhere. It's white with a blue stripe. See below...
Closest "before" photo I have. I think the wire belongs on terminal #1 of the right fuse block:
Old 08-12-2016, 11:30 AM
ROW '78 911 Targa
timmy2's Avatar
high beam indicator lamp wire.
Pull the tach and bulb to confirm if you need to. Fuse 8 on Your '74.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-12-2016, 11:37 AM
ROW '78 911 Targa
timmy2's Avatar
Dennis
Old 08-12-2016, 11:43 AM
ROW '78 911 Targa
timmy2's Avatar
Dennis
Old 08-12-2016, 11:45 AM
Thanks!
I'm going to spend some quality time tonight checking and double checking all wires and compare to my original before photos.
Terminal 8 makes sense because that is the one terminal that I got temporarily mixed up on. Easy to do since my '74 doesn't have the 3 fuses that the later cars have so lining up the panels was not as easy.
Old 08-12-2016, 12:27 PM
Jonny H's Avatar
Good info from Dennis. Looks like your dip and main pairs are the wrong way round on the bottom. Blue and blue/white come off the white pair (1&2). yellow and yellow/green come off the yellow pair(3&4). Refer to Dennis's wiring diagram.
In practice, it will mean that your dip/main functions are reversed at the stalk. if it was always like that, then your main beam warning light would have been on with the dip!!!!
www.classicretrofit.com
Old 08-12-2016, 02:35 PM
ROW '78 911 Targa
timmy2's Avatar
Just in case you don't have the '74 color schematics Vern.
https://www.dropbox.com/sh/s292jtsyvl6llw2/AABF-ofgMfoMltGa99Asphr5a?dl=0
Dennis
Old 08-12-2016, 02:52 PM
Thanks Dennis!
This is not the first time you have bailed me out
Old 08-12-2016, 06:36 PM
