-   -   Post your ITB Setup (http://forums.pelicanparts.com/porsche-911-technical-forum/925845-post-your-itb-setup.html)
michbennett902 03-16-2021 09:30 AM
Originally Posted by sbrown.nw (Post 11254028)
Interesting and thanks. Yes, I will be dropping my 3.2 targa off this Saturday for Al to install his Option 2 EFI ITB kit with rain hats.
Scott
Good luck with that Scott
sbrown.nw 03-16-2021 11:39 AM
Thanks Al and great work so far. I spoke to him a couple days ago. He is only interested in the intake parts and, right now, I am trying to sell the whole package (DME, harness and intake parts) right now..
Thanks,
Scott
Originally Posted by al lkosmal (Post 11261638)
1970 911 03-16-2021 06:13 PM
Originally Posted by winders (Post 11261161)
I have other photos but no build thread. What, specifically, are you interested in seeing?
I was initially intrigued by your removal of the rear slam panel. Looks like it has a pretty stout motor as well.
Dean
winders 03-16-2021 07:42 PM
Dean,
Yes, the rear chassis crossmember was removed. We can get away with that because of the cage and the fact the engine crossmember is quite stiff when bolted on place. Some people use additional bracing but we have no indication that this is necessary. It sure makes engine removal easier especially if I want to keep the transaxle in place.
The engine is a stout 3.6L it makes 369 RWHP and and 290 ft-lbs RWTQ. The architect is William Knight and it was built by Mat Lowrance.
1970 911 03-16-2021 07:51 PM
Originally Posted by winders (Post 11262533)
Dean,
Woah. Well done!
spyerx 03-17-2021 08:50 AM
Rasant induction/wiring/ignition. Very hot 2.8L build. Motec M130. We have had to refactor some of the harness to suit our needs, hence the stripped down loom you see...
http://forums.pelicanparts.com/uploa...1615996143.jpg
sbrown.nw 04-05-2021 10:13 AM
Here is my new setup running quite well, still needs some tuning plus a valve adjustment and oil change. Hope to pick it up this weekend.
<iframe width="907" height="680" src="https://www.youtube.com/embed/hqqpRvWZFhY" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
pampadori 04-05-2021 11:59 AM
I'm looking at the RHD setup to replace my triumphs but i just don't care for the look. Much rather a cast throttle body than a machined.
however, i do like the RHD pricing!
winders 04-05-2021 01:15 PM
If you want a great kit that performs incredibly well and looks great, look at the AT Power ITBs. No, they are not cheap. But they are not as expensive as some and you will never be sorry you got them.
Reno Rennsport sells them. Awesome ITBs.....
Nux 04-06-2021 10:11 AM
JSR Elliptical Roller Barrels
Not bad for a 2.7L street engine
http://forums.pelicanparts.com/uploa...1617728962.jpg
Showdown 04-06-2021 10:26 AM
@Nux, you pulled 271HP out of a street 2.7?
Tell me how! That's damn impressive!
sbrown.nw 04-06-2021 10:58 AM
Nice numbers. A street 2.7 that revs to 7250+ RPM, hmmmm?
Nux 04-06-2021 10:59 AM
Yes Sir :)
Not to shabby eh?
The build:
Stock (blueprinted) 2.7 short block.
10.5CR, twin plugged and lightly ported heads.
Megasquirt ECU driving coil on plug
CatCams camshafts
JSR small bore ITBs, Bosch Injectors
Original headers
M&K muffler
271HP with completely flat and smooth 279nm of torque
Dmitry at Pelican Parts 04-06-2021 11:06 AM
Found this beautiful image posted by one of our community members on 986 Forum.
http://forums.pelicanparts.com/uploa...1617732368.jpg
Nux 04-06-2021 12:24 PM
Yes it revs All the way. No problem for a.2.7
Check out out here:
https://www.instagram.com/p/CGfy_Afl9CU/?igshid=tr8fa64n8wg7
https://www.instagram.com/p/CGfVwhWl-6o/?igshid=nbsdxhhitnwo
Showdown 04-06-2021 01:04 PM
Damn, if I had what, ~10k lying around I'd be all over that. 271HP in a narrow G weighing what 2300lbs (my 77 is down to about 2250LBS)... Lord that must be fun to drive. Nice work for sure! And those videos: http://forums.pelicanparts.com/support/smileys/clap.gif
Originally Posted by Nux (Post 11286942)
Yes Sir :)
Not to shabby eh?
The build:
CatCams camshafts
Original headers
M&K muffler
sbrown.nw 04-06-2021 03:41 PM
Which component in your build list do you think is the biggest individual contributor to your the numbers below?
My build will have the following:
3.2 factory euro rebuilt from crank, heads fly cut
factory cams (wanted to go webcam 20/21 at rebuild but couldn't)
MSD streefire, keeping dizzy
XF-RHD 42-45mm throttle bodies w/ direct to head adaptors
injectors (30lb/hr)
SSIs (like the early torque the "just right tubes" introduce, many opinions on this)
Dansk 2 in 1 out (I have a targa with the top off most of the time)
Also, is the dyno known to be gracious (some are quite a bit)?
Yes Sir :)
Not to shabby eh?
The build:
CatCams camshafts
Original headers
M&K muffler
Nux 04-06-2021 10:27 PM
injectors (30lb/hr)
I believe the combination of CatCams and JSR ITBs play very well together in this particular build.
The JSRs contribute quite a bit though. We had another 3.0L twin plugged on the dyno that day, and it whent from 243hp using Triumph ITBs to 265hp using JSR ITBs. Nothing else was changed.
Also, we had a 3rd car on the dyno - a stock 3L with good exhaust, and Triumph ITBs making 215hp which was a little dissapointing imo. So the dyno is not very gracious.
sbrown.nw 04-07-2021 08:33 AM
Sounds good and thanks for the info. Al's kit has shown very nice dyno numbers on a 3.2 setup similar to mine along with a somewhat gracious dyno.
I cannot wait to drive my new setup.
Would you consider the CatCams similar to a webcam 20/21 or 964 cam?
antares 04-08-2021 11:25 AM
O.K. ... So after some 19 pages of Gold Card vibrato stories and selfies, just what kinda highway steady ankle throttle mpg's is everyone realistically now getting with 6 throttle bodies instead of having just one ? ... yeah it matters.
