“ It is recommended to mount the PN 8202, PN 82023 and 8223 coils in an upright position. The High Vibration Coil, PN 8222, can be mounted in any position due to its epoxy potting compound.” Go ahead and mount them as shown in the photo Nux posted. They’ll run great until they don’t and they will live a much shorter life. They may even leak oil or burn up a little. |
Can you explain how there can be a 42hp difference between corrected and uncorrected readings please? Is your dyno at 4000 feet elevation? |
Probably to be taken with a grain of salt, like all dyno numbers. Not to say that's not a healthy motor, but 107hp/litre through SSI's and a muffler is a bit optimistic, especially given the RPM's at peak are pretty low. |
Those numbers look really high. Al from x-faktory did a 3.2 with a very similar setup (not dual plug and US compression but did ahve SSIs and Dansk 2 in / 1 out mufler, earlier in this thread) and a very generous dyno did not show uncorrected numbers as high as this.
I am next in line for one of Al's kits to go on my 3.2 with euro compression, SSIs and Dansk 2 in / 1 out. Quote:
Another follow-up set of questions. Did you do the below dyno in 4th gear? Would be interesting to see your graph on another dyno, do you have plans to try it on another one? Is this one known to be (very) gracious in its readings? It is so expensive to get 100 hp / liter out of our 3.0 / 3.2 engines...
Don't wanna be a debbie downer here but geese wiz what with 2300 for the throttle bodies another 4500 for the plug n play electronics ... Plus COP, Cranky Fire setup, machine shop head work, tear down for cam regrind or new install ... P/C's and Barrels ... etc -
I mean why not just go out and get a 3.6, get an adaptor/clutch kit and try a plug and play with that setup ... instant 280 hp stock and no dyno needed. Without cam and dual plug, high compression your ITB setup is still looking at around 5500 just for the ITB's and Brains alone and you only get a bump up of about 200 +/-10 hp rear wheel if truth be told IF your lucky and have a leaky sport muffler. Yeah @sbrown It sure is tough and silly E$pensive going this ITB route for such ridiculous and laughable returns for that kinda out lay. |
Link to piles of affordable 3.6s plsthx
http://forums.pelicanparts.com/uploa...1614341425.jpg
1984 full build for customer. Waiting on some small stuff and hopefully fire up this week |
Said it before, saying it again. Flywheel HP is USELESS. Unless the numbers were generated on an engine dyno and even then it isn't reality. I never understand people running cars on a chassis dyno and then extrapolating flywheel HP. I guess it gives a better number for feeding people's egos, but come on man...Tell us what is the uncorrected RWHP that the setup generated? What kind of dyno was it on also...Mustang dynos are easy to fudge because you have to input a bunch of variables and that give you lots of ways to inflate...DynoJets are the industry standards (IMO) and are generally pretty consistent from machine to machine.
@shamrock ... there are engines out there ... yes u have to go on a safari and hunt them down. Many avenues to approach this pathway. Mechanics, Insurance Co's, Yards, Engine builders etc. Affordable ? Yes subjective and yet I addressed some of the expenses involved with attempting to max out a 3.0 to the point u might as well just go on a 3.6 safari hunt. You are never gonna get anything with a 3.0-3.2 that even approaches a stock 3.6 without basically re-inventing the old platform. Yeah got to admit, you get a neat sound from the ITB's, credit card bragging rights and wine cork sniffing providence rights from your man cave but ya not gonna get 300 hp cause after all speed is like a line of coke. The more you have the more you want. - uncle dave
The "...not a requirement..." comment was meant to state that I don't think you need to be a professional engine builder to be taken seriously here. Regarding the coil leaking: My '75 arrived to me with a stock Bosch coil mounted with the output terminal pointed down. It was leaking from the other end of the coil (bottom of the coil but also the highest point as it was mounted upside down) where it contacted the AC coil mounted on the engine deck lid. Vibration wore through both the AC coil and the ignition coil case. My ignition coil was leaking oil, but not from where the can got crimped around the insulator. |
How did your car turn out?
The car is quieter at idle and cruise. The exhaust note is higher pitched. It roars when you add throttle/load and the valves open. The car has really come alive in the mid range and up. The part throttle response is incredible. I felt it most often when weaving between cars on the freeway, but tbh I haven't driven it that much because the rear bumper is still off. It goes to the body shop in two weeks for the rear bumper to be modified to accommodate the new center exit exhaust. As to intake sound, I think the GT3 plenum mutes that considerably. I do get some brilliant new intake notes when I come off throttle. If you want intake sound then suggest you go with trumpets. |
| All times are GMT -8. The time now is 05:15 AM. |
