Very cool! I'll reach out to you next time we're doing one.
Love mine so sharing as well.
I just acquired a 1997 engine in an 88 Carrera Coupe -3.6 ,with
KMS engine management and itb's-System is a KMS25 sport cams ,Rarly headers 2/2 rsr muffler w jethot coated headers and muff. MP25 management ECU Specs are listed below-(they are big with the BMW guys) System has been used in a exclusive use track car for the last 5-6 years with 100 % reliability. <http://kms.vankronenburg.nl/wp-content/uploads/2012/03/01-01-01-0001prof.j pg> The KMS MP25 ECU is an affordable and efficient engine management system. By using the minimum of sensors, three auxiliary outputs, one auxiliary input and a wide range of functions, the KMS MP25 ECU can cope with 90% of all types of Otto engines. These basic functions make the MP25 a simple, reliable and effective engine management system at a very competitive price. ‘This is a engine management system designed by engine people to be used by engine people. Anyone who understands the mechanics of the Otto cycle, should be able to set up and use this system with little difficulty.’ Features: * Complete engine management system up to 10 cylinders * Self-learning lambda control in combination with KMS UEGO controllers * Engine diagnostics * Short cut protected outputs * Serial RS232 communication * External dashboard (KMS CAN display in combination with interface) * 2 engine load sensors * Analogue input (2nd lambda, gearbox position, G-force sensor, EGT, etc.) * 3 auxiliary outputs (Shiftlight, water-injection, cooling fan, etc.) * Pit lane limiter (variable) * RPM limiter * A.L.S. (variable) * Powershift (separate delay and cut-off time for each gear) * Boost control * Launch control (variable) * Idle control
1979 SC 1986 Carrera 3.6 L+ |
Chain fence eating turbo
^^^^^ Not a good sign their webpage is not active!!!
Wer bremst verliert
It looks like the poster's error: he copied the url for a picture of their ecu but when the forum renders the page it de-linked "pg" from the end of the address which SHOULD be ".jpg." Add back the "pg" at the end and the pic of the ecu comes up properly.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
I have been thinking of going with ITB's after speaking with Al about a rebuild.
At this point I have a pretty good running 3.2 (other than oil leaks) with Motronic DME. What should I expect changing to ITB's and how would they compare to the Motronic FI currently on the car. Thanks, Rich
Looking for a 1970-1973 911 coupe, no sunroof. Matching numbers and originality are unimportant. |
Hey Al, do those S3 ITB's come polished? Is there a reason they aren't lined up and perpendicular?
I'm shopping around for a running 3.2. In the future, ITB/EFI/EMS is a definite thing. |
Still not done Making the plenums and intercooler. But here is the link to mine, it's a turbo so a little different . I made my own manifolds got the ITB's from Jenevy and also the linkage.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/763281-well-i-its-finally-time-pull-out-efi-swap-will-long-one.html
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
ITBs
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Cars Ruined My Life
pretty active to me LOOK HERE
they seem to be not so much into social media. Velocity stacks for the M cars are delicious. |
Cars Ruined My Life
thanks....give me a shout and we can discuss. regards, al
The KMS stuff seems way legit. I had them quote me the setup, before I decided to stick with carbs and a 12 plug.
https://www.youtube.com/watch?v=Fqkzn5IMOFI |
Dzug Dyno
Here's a dyno run of the Dzug 3.2SS...the dyno sheet is a composite that shows the before and after. Before is Bosch CIS, after is my x-faktory EFI/ITB system...no other changes were made. (dotted lines are before, solid lines after)
a couple vids..one of pre-dyno road test and one of dyno run https://www.youtube.com/watch?v=pxXwaL_TdmY https://youtu.be/xaj0FyEmc68 ![]() ![]() I wish those guys were still around...they had mad skillz.... regards, al Al Kosmal the x-faktory koz@x-faktory.com RGruppe #669 X-Faktory - Home
Holy smokes!! Beauty all around.. That plenum! Totally custom fabbed I assume? And that air filter.. is that something off the shelf? Very cool.
'82 SC Coupe / Pacific Blue |
Ferrino, thanks for the reply.
That sounds good, I would be looking for the same characteristics. Rich
I would rather be driving
I have been installing EFI using MFI stacks. This retains all of the factory induction for early cars. Includes flex line fuel feed like the RSR-MFI systems.
Currently building 2X 3.0s and a 2.8 with the same system. This does require MFI ports installed into the head. Available from our host.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
