Mr Sydney - great looking engine and that's pretty much what I'm going for. Can you confirm what sits inside the interconnecting pipe work, is that where the resonance flap is? Is the filter t piece 'hollow' ?
Yep, resonance flap. The kit was supplied by Rothsport and controlled by Motec. Build thread here http://forums.pelicanparts.com/porsche-964-993-technical-forum/822904-carrera-rs-4-build.html |
throttle body setup and Motec programming. Just staggering performance across the rev range. |
http://forums.pelicanparts.com/support/smileys/grin.gif |
The principle is to make things simpler and create less restriction in the intake not more :) |
Would love to see a dyno plot? |
You don't want to use a MAF sensor on an ITB set up. I use a MAP (Manifold Air Pressure), TPS (Throttle Positoin Sensor) and rpm which combined is known as Load Sensing and @xn, corrected for temperature and altitude. Works very well!
I talked to Jeff about this just the other day. In my future.
Is it just me, or is this thread generating more interest than the 'chest' thread used to generate?
Bill K |
The thread turned out better than I thought, but I could use more info on some of these set ups. I'd love to try to work some of this out in the garage at home without having to buy into someone else's kit, but that might be wishful thinking.
-Steve |
With ITB's throttle angle is the most precise and fastest engine air requirement parameter. But since density changes with temperature and humidity it needs some compensation.
Factories use MAF because it compensates for small VE changes over engine life due to wear, use of different components etc. For example when BMW M3 (E46) MAF sensor fails, ECU goes to Alpha-N mode. And M3 CSL (E46) uses Alpha-N from the factory, if it would be so bad they wouldn't have went that route :) |
regards, al |
I have decided to go the tried and true route of Triumph 955i ITBs and a MS2 control unit (or AEM Infinity, depending on garage clean out success).
I have sourced out manifolds but linkage may be an issue. I'm thinking of making my own motorcycle style cables to connect with the stock SC throttle, but I'd love to hear some of your thoughts on this guys. I know there is at least one company on the web offering a modified weber style linkage, but at $500 its a bit pricey for what you actually get. |
http://forums.pelicanparts.com/uploa...1475477090.jpg
TWM bodies with a DTA S80 pro ECU, soon to have Fly by wire add on using a Jenvey throttle motor. Originally I was going to use an old bmw 3.0 DME to run this but decided the extra features the DTA has would be useful in future. The car screams all the to 7200rpm. |
The Singer uses some type of plenum with ITBs. Anyone know anything about it? Other than the fact that it looks awesome? Looks similar to Jeff Gamroths. This motor was built by Ed Pink.
If I remember correctly they use the AEM ECU. http://forums.pelicanparts.com/uploa...1475496132.jpg |
| All times are GMT -8. The time now is 05:46 PM. |
