[QUOTE=VZ935;9478876]Early Andial 962 itb's rebuilt by Matt Blast
http://forums.pelicanparts.com/uploa...1487443340.jpg You win :) |
Here's mine: PMO 46's run by Motec. Bosch 044 fuel pump. I'm on vacation right now and don't remember the injectors or pressure regulator. 3.8 motor with careful port work and a slightly hotter cam making 370 hp and 315 lbft. The early factory airbox in the picture was tested but found to me too small to support the needed airflow. Max power and torque were reached with K&N air filters and a early factory style 2 in and 2 out sport muffler. Headers are B&B 1 3/4".
http://forums.pelicanparts.com/uploa...1487477502.jpg |
Beautiful engine Brooke...................
regards, al |
RSR slides used with efi and a 962 flat fan on a 3.4 http://forums.pelicanparts.com/uploa...1487485209.jpg http://forums.pelicanparts.com/uploa...1487485223.jpg |
That looks sharp! Is it a Gamroth motor?
Did you consider cutting strategic areas out of the early airbox and replacing with screen to increase flow? Quote:
Ran an upside down 935 box
Interesting, thanks.
Here's mine... set to go on twin plug 3.0/3.2ss,
http://forums.pelicanparts.com/uploa...1488128647.jpg |
Twm
regards, al |
Long shot but has anyone noticed any major differences on the (butt) dyno between PMO and Jenveys?
Will be going with the Rasant ?? Aem Infinity set-up as I have two of these I will end-up doing and would like to be able to duplicate some of the effort. Although the 2nd eng is already 3.4 running Carrera intake.. which will stay. Definitely plan on reaching out to you for some instruction, detail, etc.. Thx |
X-Faktory - Home |
Nice looking engine Chris........details plz...
regards, al |
3.5 we built a few years ago with PMOs. The next one will use Jenveys again like our previous motors.
http://forums.pelicanparts.com/uploa...1488601344.jpg Cheers |
From several years ago. Home built 49mm throttles on a cammed 3.6.
http://forums.pelicanparts.com/uploa...1488605571.JPG |
| All times are GMT -8. The time now is 10:22 AM. |
